Question about Microwave Ovens
Everything works perfectly (oven, grill, etc) on my combi microwave except the microwave is it only a fuse? if so how do I change it? or should I just bin it
  • 99 Answers
It is a safety fuse !but somthing has made it blow,and needs checking by microwave engineer.Possibly door interlock fault.Micros can kill even when UNPLUGGED be carefull. If you live in cheshire we can FIX IT Grandadfixer
Posted on Nov 05, 2008
My miele combi oven microwave doesn't heat but oven is fine!
Probably a faulty door switch has blown the microwave fuse. If you are lucky.
Nov 17, 2017 | Microwave Ovens
Electrolux combi integral microwave EMS26414W does not microwave/defrost.The display/turntable/light/grill does work
Failure should be found in the high voltage section of microwave oven.
Magnetron, HV capacitor, HV diode or HV fuse, tranformer HV secondary coil
Dado
May 27, 2014 | Electrolux Microwave Ovens
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Tesco Combi Microwave-doesn't cook but grills ok
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 08, 2009 | Emerson MW8777W Microwave Oven
Where is the 10 amp fuse on my delonghi micro/combo/grill please
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
Dec 28, 2008 | DeLonghi MW 605 Convection/Microwave Oven
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Jul 25, 2008 | Microwave Ovens
Belling CJ ss 25 Microwave Combi
I would suspect a bad magnetron or a loose connection at the magnetron's terminals or possibly another high voltage part (such as a shorted diode or bad transformer).
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Otherwise, I would contact the manufacturer or your local microwave / appliance repair center for service.
Good luck.
May 29, 2008 | Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
