Toshiba m105-s3084 I am trying to upgrade the ram to 4GB via 2x2GB chips but i can only find one slot is there another one hidden or is there just one?
  • scott57uk Nov 08, 2008
    On this computor one of the slots is in the back of the unit the other is under the keyboard. You must remove the key board to access it.
  • 488 Answers
Hi!if its the Toshiba m105-s3084 your asking about then it has two slots and can support maximum of 4GB..please see this link..
please go through the manual at for knowing how to install more memory..
you will need to make free and fast account..
hope it helps!
Posted on Nov 05, 2008
  • 3 Answers
Number of Slots:
Slot 1 Slot 2 Normally you will find the 2 slots, one above the other.
Each memory slot can hold DDR2 PC2-5300,DDR2 PC2-4200 with a maximum of 2GB per slot.*
*Not to exceed manufacturer supported memory. Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules. Make sure that both are fully seated prior to powering up the laptop.
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
Toshiba M115-S3144 that freezes after starting
make sure your ram is upgraded to max capacity
DDR2 PC2-5300 2x2gb chips
update windows including ALL optional updates
Jan 10, 2013 | Toshiba Satellite M105-S1021 Notebook
Hi . i have toshiba satellite m105-s3084. i really need to upgrade my notebook performance. can i upgrade my processor into core 2 duo? thanks. (
Here is a list of compatible processors for your notebook. Just click Processors in section Compatible products and you'll see which core 2 duo processors are supported.
Sep 05, 2011 | Toshiba Satellite P100 Notebook
The sound on my satellite m105-s3084 stopped working
Go to device manager, if the sound card has a yellow exclamation point near it, then the driver is at fault. You can simply reinstall the driver or remove the sound card and restart the computer. Windows will discover the sound card and install the driver
May 02, 2009 | Toshiba Satellite M105-S3084 Notebook
Hi there.
The memory slots are more or less on top of each other.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Acer Aspire 4315 Notebook
Memory upgrade not working
check front side bus for new ram & old ram ,sometimes if both are working on differant f.s.b. then also this can be happen
Mar 15, 2009 | Toshiba Satellite A135-S4527 Notebook
Cant get pass bio screen on satellite m105-s3084 toshiba
The Toshiba BIOS password is stored on an EEPROM chip and removing the BIOS battery won't work. There is a hardware hack solution (a dongle) to remove the password.
Buy a 25 pin male D Sub connector and join the following pins together by soldering wires to these pins. Make sure the wires do not short against each other. The pins are numbered on the connector.
Plug the dongle into the printer port of your laptop and power up the laptop. Press F2 function key to get into the BIOS and then remove the password. Your laptop should boot up without the password and you can remove the dongle.
Feb 10, 2009 | Toshiba Satellite M105-S3084 Notebook
Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory...
Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
Please don't forget to rate this solution.
Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
I have a Toshiba Satellite M105-s1021. I try to upgrade from 1.5gb ram to 2.0gb ram and i get a blue screen of death. I switch the slots that the chips are in and then i get nothing but a black screen...
Dear Tom,
ITs seems that there is a compatibility issue with your new 2.0 GB Memory module, please check the frequancy of these ram.
Be Happy Always
Dec 04, 2008 | Toshiba Satellite M105-S1021 Notebook
Need instruction on how to install memory upgrade
First you have to determine whether this model can support 4Gb or memory.
All laptops use the same memory. SODIMM (Small Outline Dual Inline Memory Module) chips are readily available. It's actually quite easy to upgrade. First remove the small piece of the casing that covers the top part of the keyboard. This should just snap off. Then you should find some screws holding the top of the keyboard to the case. Once you remove these, the keyboard will easily pop out. Carefully disconnect the ribbon cable connector leading to the keyboard. Then you should have access to the RAM chips.
Therefore, the only tool you really need is a small phillips screwdriver. Be careful when handling the chips.
Sep 06, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
210 people viewed this question
David Payne
David Payne
