Question about Yamaha HTR-5250 Receiver
Powers on but immediately shuts down
My receiver has been sitting in a garage for about 12 months now. During the summers here it gets to be around 100 F and in the winters it is around 75 F so you can imagine what it has been exposed to (I know - very stupid on my part to leave it in the garage). I hooked it up today and it will turn on for about 2 seconds later it shurts right back off. No matter how many times I press the power button (I tried 20+ times once) it would never stay on. It just kept powering off immediately. I tried changing to a different outlet but got the same problem. Any thoughts? Is tehre a fuse that might be tripping?
  • bluefrog Mar 13, 2008
    My Yamaha HTR 5250 won't turn on. I hear it "click" as if it is going to turn on then, right away, I hear a second click and it doesn't turn on. Ideas?
  • jon_hilden20 Dec 14, 2008
    Bummer - I have the same problem...(and no better answers)
    President:
  • 3,130 Answers
No I hate to be the one to give you the bad news but most likly the capacitors in the power supply or the output circuit of this reciver, are bad and most likly need to be overhouled. Or there is mosture contamination on the printed circuit board. It is time to let go and buy a new reciver, unless you want to invest big bucks into the repair of this reciver, as Im sure it can be repaired, but at what cost??
Posted on Oct 08, 2006
    New Friend:
Http://www.youtube.com/watch?v=keaq2F4LrU4
Posted on Feb 17, 2013
Insignia receiver powers up then immediately shuts down
Sounds like the wires touching shorted out one of the amp ic's. Would have to get that ic replaced before it will power up again.
Jan 16, 2014 | Audio Players & Recorders
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
2001 Nissan Altima shuts off in hot weather
it is the cam position sensor...the telltale sign of the failure is that it happens when the vehicle is warm and has been driven for a while. Sensor is about 40 bucks at the auto parts store, make sure the replacement sensor is metal, not plastic.
The main symptoms of this sensor failing are rough starts, rough idling and not starting at all especially when warm.
May 20, 2012 | 2001 Nissan Altima
While plugged in to power laptop tfreezes and turns off and on during startup....on charged battery starts ok..battery goes flat , plug power in laptop shuts down
Maybe your laptop is overheating. Does it power back on immediately when you were using the power cord or do you have to wait and let it sit a while to cool off before it powers back on?
Do you hear the fans running when you power on the laptop?
Laptops overheat because of:
1) Dust around the vents, CPU and Heat Sink. Dust inside the laptop.
2) A Fan that is not working
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the laptop cool.
Apr 08, 2012 | Computers & Internet
99 Windstar starts fine in winter but not during summer or spring
its vapor locking, losen the fuel cap the next time it does it if that takes care of the problem then replace the fuel cap!!!
Feb 22, 2010 | 1999 Ford Windstar
Receiver powers on then shuts down. Any mode (CD AUX,VIDEO,etc) will cause same result. Sometimes FM mode will keep receiver on for longer. Once speakers are connceted, shut down happens no matter which...
If it's not happening when your speakers are disconnected, your problem is not in the receiver, it's either a wire touching at the terminals on the rear of the receiver, or a bad voice coil or crossover in your speaker. If you re connect the speakers and it immediately cuts out, disconnect all speakers and reconnect one by one testing the receiver each time until your receiver shuts off or remains on with all wires connected and you've fixed the problem. If it cuts out, disconnect the problem speaker at the speaker and test again. If it stays on, problem is in the speaker, if it still cuts out, problem is in the wire. Hope this helps. If you need further help, post a comment and I can help you troubleshoot some more.
Aug 11, 2009 | NAD C730 Receiver
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Craftman garage door opener, will not go all the way up.
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
    1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of               lubricant (not WD 40)
    2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken           or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling          and reads Craftsman). If the light(s) on your operator go from front and/or back, the force                      adjustment screw is on the back of the operator. If the lights are on the sides of the operator then          the force adjustment screw is on the right side (looking from the back of the operator and facing            the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Nov 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Yamaha HTR-5250 Receiver Logo
312 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
