Question about Samsung Office Equipment & Supplies
My samsung sf 345tp fax machine keeps saying change cartridge - which i have done and it will not change the message or print etc
SOURCE: Printer cartridge alignment
Pressing "setup" and "options" together works for me.
Posted on Aug 07, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Samsung SF-5100P
Machine will require fuser(hot bit at rear) replaced before it will operate, take to dealer for quote or if brave and 240v happy then buy a fuser and get your tools out rip off the covers and in the back you will find fuser assy.
link to service item fuser U.S.
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=JC96%2D01621A&search%5Fmodel=SF5100
Posted on Nov 14, 2007
  • 75 Answers
SOURCE: CARTRIDGE PROBLEM
check ur cartridge if they have ink left, or replace new ink cartridge.
Posted on Mar 07, 2008
  • 105 Answers
SOURCE: "Toner Low" message = no faxes :(
Need to do a hard reset. Contact Dell for instructions, but it will involve turning printer off, opening front cover, pushing buttons on front panel in certain sequence, etc. Each model differs, which is why you should call Dell.
Posted on Mar 27, 2008
SOURCE: Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Posted on Jun 03, 2008
I have a samsung sf-760p i just changed the toner cartridge it is just showing not compatible toner cartridge but am using the original toner cartridge. so what can be the solution for this problem??
I suspect you think you are using a genuine samsung cartridge but its simply not. The machine is looking at the chip in the cartridge and its not genuine. I suspect your cartridge did not come out of a genuine blue and white Samsung box or its similar but not the correct one.
Dec 02, 2015 | Samsung Sf-760p Laser Print/copy/fax/scan
How do I clean the printer head of my Samsung SF335T? I have just installed a new cartridge and the machine isn't printing.
A machine cleanig test is available under the maintenance menu of the machine. A manual cleaning can be done be cleaning the cartridge with a soft cloth and warm water. also clean the connections between the cartridge and the main head piece ( the little copper connections on cartridge and cartridge tray) if it still does not print, the flat cable is the problem. ALL CLEANING CAN BE DONE WITHOUT REMOVING ONE SCREW.
Jul 29, 2011 | Samsung SF-335T Plain Paper Inkjet Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Only copying 1/2 the page how do i fix
hi my print is saying no cartridge what is the problem samsung model no sf-3200
Feb 07, 2010 | Samsung SF-3200 Fax
Hi, My SF 360 keeps flashing up " clear cartridge channel/paper jam and press start. Every time this is done/sorted, the cartridge goes onto "printing" then stops in the middle of the carriage - the the...
In your fax machine is a thin shaft. Clean it with a dry cloth to take away the dirt to prevent from getting stuck or if that does not work,try another cartrige. If that also not work,then there is somthing wrong with the print head.
Aug 25, 2009 | Samsung Office Equipment & Supplies
Samsung SF-340 wont print
Unplug the power cord for 10 seconds.
Nov 07, 2008 | Samsung SF-340 Plain Paper Inkjet Fax
Samung Sf-330 fax.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
