Question about Kenmore 43042 Front Load Washer
Kenmore Washing Machine doesn't rinse
I have Kenmore Sears Canada washing machine. Model no. C110 4815081. It works fine but it doesn't rinse. Clothes remain wet even at rinse cycle. I don't what might be the problem. Any suggestions what i can check to correct this. thanks
  • 641 Answers
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Posted on Aug 17, 2007
Why did my washing machine stop spinning?
Not knowing the age or model of your washer it's hard to say but if it is the older direct drive then it's a bad lid switch!
Dec 08, 2015 | Kenmore Washing Machines
Any recalls on Kenmore Model # 110.20022012 Washing machine?
I think that your "LID Switch" is broken, go to www.sears.com/parts and put your model number in and you'll see the lid switch listed.
Aug 28, 2014 | Kenmore Washing Machines
I have set the rinse cycle set to cold on our washing machine, however the clothes are rinsed hot, when I take the clothes out of the washing machine after the cycle is complete they are hot. How do I...
the hoses may be reversed...select cold rinse and turn on washer...if its hot..then try cold wash, is it hot? then try hot wash...is it cold? if so, check your hoses are on correctly....reverse hose's
Jan 23, 2011 | Kenmore Washing Machines
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Rinse cycle does not work on washing machine
Sounds like a belt or clutch issue. What is the make and model #?
Nov 02, 2017 | Kenmore Washing Machines
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Feb 04, 2009 | Kenmore 24032\24036 Top Load Washer
Lint on clothes
The lint filter should be in the agitator. Pull the softener dispenser off the top of the agitator and check for a filter. You might even find that the agitator shaft is very dirty. Put through a warm wash with a solution of 1 cup vinegar to one cup bicarbonate of soda and let it go through complete wash. This should solve the problem.
Oct 14, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 43042 Front Load Washer Logo
270 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
