Electrolux Washer Dryer EWX14440w giving error 10
Hello Ladies & Gents,
I have an Electrolux EWX14440w (washer dryer) it gives an error 10 flashing red message, which according to the manual is related to water supply.
However if I put it on rinse it will fill up & rinse & then on drain it will drain. If I put it on a normal wash it will start, go through a few minutes and then come up with error 10.
Since the water tap is on, the water is getting through (i.e. the filter is not blocked) and it is filling, is it possible the water level switch is not detecting the water level & needs to be replaced?
Thank you for all your assistance in advance.
Kind Regards
Annita
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 142 Answers
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Posted on Jun 02, 2009
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Posted on Jun 11, 2009
What is Error HI?
you didn't mention the model, but on the washer/dryer combo units, the H1 means the following:
Dryer temperature sensor error detected A fault has been detected with the dryer temperature sensor on washer dryer models.
  • Check connections to dryer sensor
  • Check temperature sensor
May 15, 2016 | Daewoo Washing Machines
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
What could it be
Hello Reese,
I see that you're having a Problem with your Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer. I see that the washer will not work until dryer is turned on and the dryer will not heat. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the appliance is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back on and try to restart it. If you are still having trouble with the washer not working until dryer is turned on and the dryer will not heat. I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 20, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Hello I have a washing machine EWX14440W and the green Start Pause LED light is flashing. I have cleaned the fluff filter, turned off the mains and turned it back on again, done a short dry cycle...
http://data.manualslib.com/pdf/5/461/46091-electrolux/ewx_14440_w.pdf?dabc55afaee556910dced33ebba5ef18
This is the manual on your machine. Unfortunately there is no info on the blinking light so I am assuming that it is a delayed start. Now remember this is a high efficiency machine so it may not seem like it is doing anything when it is. As far as the drying part is concerned, check your drying temp. selection.
Dec 10, 2013 | Electrolux Washing Machines
Electrolux washer dryer EWX14440W. It just seems to have died. No power, noise, lights, error codes or other signs of life. Can anyone advise where to start?
check fuse in plug ,check main circuit breaker tripped also do u have a neon switch on wall in room check this fuse also, to check scoket out let plug some thing else thats works to check out scoket out let
Aug 31, 2013 | Electrolux Washing Machines
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
Electrolux washer dryer ewd 1409 start and pause light keeps flashing
That is a generic error code - please reset the unit at the household circuit breaker for about 10-15 minutes, and then retry the unit. No difference - please consult a professional.
Aug 22, 2012 | Electrolux EW1000i Front Load Washer
Hi, I have an Electrolux EWF1087 which is flashing an E50 error message. Can you tell me what that error message means? Thanks Gary.
HELLO GARY E50 error is to do with the motor, it can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Jun 05, 2010 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
175 people viewed this question
Top Washing Machines Experts
