SONY 32"CRT MODEL KV32FX68U FLASHES TWICE CHANGED TRANSFORMER STILL FLASHING TWICE
  • 4,234 Answers
THe 2 blinks is an over-current fault in most cases. Usually this translates into the horizontal output transistor being shorted. Have you checked that yet?
Dan
Posted on Nov 05, 2008
Tv will not turn on. red light blinks but nothing happens. sony wega kv30hs510
How many red flashes? Mine is flashing twice every 5 seconds and ended up getting a tv engineer to have a look. He has confirmed a faulty transformer approx. £120 to replace
Nov 23, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
My triniton wega tv 32 inch flashes 5 times and i lose the picture then it comes back on lasts awhile then lose the picture again flashes 5 times again over and over
you can ensure the connection and Heater's voltage, start from Flyback transformer ( Heater Pin) to Heater of the CRT tube, whether exist and normal ( Include : check Resistor in Heater area), perhaps there is lost connection for a while and connect gain. There should be 5 Volt AC available. otherwise check the socket of CRT Tube, unplug and clean it. If there is any question you can ask me and clarification with detail result from my solution.
Aug 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a kv-32ls60u Sony TV. It blinks 5 times
The most common failures are the flyback transformer assembly and sometimes some of its support components, and or there is the possibility of a short in the CRT electron gun. In either case, the power supply is going in to protect mode, and the uPC is sending this flashing error code to the front LED.
I have no idea if the flyback transformer assembly is still available, but I am very sure the CRT is no longer available. In any case you will find the cost of servicing your set to be expensive for its age. The last time I checked, the cost of the CRT exceeded the replacement cost of the set.
Jerry G.
Nov 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony 32'' I think. model # KV-32FS10, serial #8047927, made Jan 2000. During a move, the tv was dropped and now when you press the power, your hear the click, the red click light flashes...
It sounds like that in the drop you may have cracked the main PCB. The PCB's usually crack around the heaviest part of the PCB. Probably around the flyback transformer.
Oct 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Aug 25, 2009 | Sony KV-32S45 32" TV
Timer button blinks but doesn't turn on
There are several faults that can cause this. Shorted diodes in the high voltage, a bad flyback transformer, a shorted CRT driver IC. None of them are very easy to fix.
Mar 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Flashing/sparking of image
no doubt. replace LOT and horizontal output transformer with new one
Jan 26, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
