Question about Plantronics - Bluetooth Headset Plus Base & Headset
Plantronics voyager 510 headset
My headset just stopped working. It has power. The red light is flashing on the base unit. The blue light on the headset is on, but the blue light on the top switch of the base unit will not light. I have checked the power and the connection to the phone. What else should I do?
  • 5 more comments
  • paulajo321 Nov 06, 2008
    Thank you. This worked perfectly.
  • ALuria0 Nov 19, 2008
    I am having the same issue; i can pair my headset with my cell phone; but on the base; the red light is blinking; the blue light won't come on and the when i try to pair the headset to the base it appears to work (blue blinking light). any suggetions
  • Anonymous Nov 21, 2008
    I am having the sameproblem; i can pair my headset with my office phone; but on the base; the red light is blinking but the blue one doesn't Suggetions plis!!
  • danfithen Jan 04, 2009
    I just bought a palntronics Voyager 510 online, and it didn't have a manual. How do I pair it to my phone? Its charged and comes on just fine.
  • Anonymous Mar 19, 2014
    It's been just two weeks since I bought Plantronics 240 bluetooth headset, it has been working fine till yesterday, but after re-charging I'm not able to switch off the device. Even if I press power on/off switch, the blue light is always on not even blinking. Is there any way to switch it off. However I'm able to answer all calls.
  • Anonymous Mar 23, 2014
    How do you turn the flashing blue light off and the headset will still be in standby mode and powered on?
    On a blue parrot bx250 xt How do you turn the flashing blue light off and the headset will still be in standby mode and powered on?
  • 16 Answers
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Posted on Nov 05, 2008
2 Suggested Answers
  • 5 Answers
SOURCE: Plantronics Voyager 500a Bluetooth Headset
Try re-syncing the headset to the base unit:
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
Posted on Jan 07, 2011
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Just purchased the quantico phone trying to pair it with my plantronic 510 headset but need help
Press and hold both the Speak Volume Adjust Buttons on the base unit until
the indicator in the Call Control Button starts to flash.
Press and hold the headset Listen Volume Adjust + Button and headset Call
Control Button until the Status Indicator flashes red and blue.
Pairing completion is indicated when the Call Control Button indicator
illuminates solidly, and the Status Indicator flashes
Here is link to manual if you need it:
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager510_ug_gb.pdf?WT.dl=20
Good luck
Apr 16, 2011 | Plantronics 510 Voyager Headset - PLN-510...
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Good afternoon, I´m trying to
Have you tried:
I was searching for this today and happened to find the above on the plantronics website. It definitely frustrated me till I found out about how to put the base in pairing mode.
Jan 03, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Jun 22, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Blue light blinks all the time its on
Plantronics 510 Voyager Headset - PLN-510 Headset - Light blinking blue.
Good! You'll be happy to know, this is normal.
The Status Indicator flashes blue when the headset is on. When the battery becomes low, the indicator will flash red.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 06, 2010 | Plantronics 510 Voyager Headset - PLN-510...
How do you sync a plantronics 510?
allanrecht
The steps below will show you how to put your Voyager 510 into pairing mode.
To put the headset into pairing mode:
1 - Start with the headset powered on (the headset will have a blue blinking light).
2 - Press in and hold the + side of the volume button (long, thin and silver) and the Call Control Button (on the
microphone boom, oval shaped) until the headset flashes red, blue, red, blue.
3 - Tell your phone to "Find the new Bluetooth device" (see the User Guide or call a local phone store).
4 - If the phone asks for a User Code or passkey, enter 0000 (four zeros).
Issken
Jan 25, 2010 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics - Bluetooth Headset Plus Base & Headset Logo
2,026 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
