I just bought a 1996 Vulcan and it needs a new starter, Well i removed the starter and the gears are bad , i believe this is a drive gear, can someone help me? I need to know what the gear is called? and how hard it is to replace it. The new starter would not grab the gear and will not start. Its the gear the starter connects to, to turn over the motor
SOURCE: Keeps jumping out of second gear. Tore down the
The gears ARE probably fine. The problem is a slightly bent shift fork. Since the engine is apart I would STRONGLY advise you replace the shift fork. If nothing else it is cheap insurance that you won't have to replace it four weeks later because it won't shift into first. I have replaced shift forks that looked perfectly good but were bent such the you couldn't get into 2nd gear. Looks can be deceiving.
SOURCE: Any way to adjust the rear shocks on a 1996 vulcan 1500-a10 ?
on the bottom chrome band there are like four holes. in your tool kit there is a "thing-a-ma-gidgette" (i call it this because it looks like one, it is actually a "spoke wrench"). the tail of the spoke wrench will fit in the 4 holes Righty tighty so it feels weird: one side you are turning towards the front one side towards the back.
SOURCE: slipping in first gear - 1996 Kawasaki Vulcan VN1500
only two things going on here, first the clutch is out of adjustment, no enough free play, the next is the clutch plates and springs need replacing.
SOURCE: I have a 1996 Vulcan 88 1500. Cranks but will not start.
Is there gas? Is the petcock on? Are you getting gas to the carbs? Are you getting spark? If yes to all these then you may have timing issues.
SOURCE: What is the gear ratios and final drive ratios on
For the gears:
Gear ratios:1st
2.500 (40/16)
2nd
1.590 (35/22)
3rd
1.192 (31/26)
4th
0.965 (28/29)
5th
0.781 (25/32)
Final Reduction Ratio
2.619 (15/21 x 33/9) and the final drive is a shaft drive.
