posted by flee on Oct 08, 2006
While recording, it will only pick up lights such as lamps etc. It will play previously recorded footage just fine.
Solution #1
posted on Oct 10, 2006
if it is only recording bright light sources then it must be working fine outdoors in broad day light. if so, it means the auto iris of your camera has stucked to minimum opening. was the camera lying idle for long time. try pointing the camera towards low light and bright light with quick moves.some times by doing so it gives a little jerk to the mechanism and it starts working, or lightly patting the camera on the lense side may solve the problem. otherwise let the repaires earn some money.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Quasar VM-L152 VHS-C Analog Camcorder
Email this problem
Email this problem
Can you Help with these Camcorders problems?
quasar palmcorder
quasar palmcorder
is stuck on pause and then it... Answer This...
black and white recordings
Is it possible to record videos... Answer This...
poor resolution
poor resolution
when i edit movies 2 make in to... Answer This...
Records but no sound
My 2003 quasar video camera... Answer This...
Repair Service
Find Camcorder Repairman Near You:
