Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washer refuses to move to next cycle
Hi, My washer is filling with water, then refuses to move to the next cycle.  It does not attempt to move, there is no noise of any kind indicating that it is trying.  I have manually moved the dial to each cycle and get no response.  No draining, no agitating, no spinning, no sound, no nothing.
  • 99 Answers
Can you still open door when it has filled?If so it is intermittant door lock .If no new progame card required.
Posted on Nov 05, 2008
Why does washer say no water and refuse to complete cycle?
Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, please confirm that the house valves are fully turned on. Otherwise, typically, faulty switch does not allow the valve inside to turn or a kinked fill hose. Other possibilities of more potential serious issues are water valve faults, faulty control board, pressure switch or wiring failure. If I was in your position, I will personally consult a professional to move forward accurately and assist with the repairs.
Jul 11, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Washing machine keeps filling and draining at the same time and wont fill enough to move on to the next cycle
The drain hose is too low and the water just runs right out...The highest point of the drain hose needs to be higher then the top of the washer before it goes back down into the drain. Also if the hose is sticking into water it can create a siphon which pulls the water out of the washer... make sure that you also have an air gap...
Heatman101
Mar 10, 2010 | Frigidaire FGX831C Top Load Stacked Washer...
Top loading GE color profile washer (wpse4200a) won't fill
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Sep 19, 2009 | Washing Machines
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Will not move to the next cycle.
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    Washer fills but won t advance to the next setting for all cycle
    Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
    Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing machine fills, but won't agitate
    maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
    Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
    sound like the lid switch is open, if that doesn;t fix it try the water level switch
    Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
    122 people viewed this question
    Top Hotpoint Washing Machines Experts
    hungoverrr
    Level 1 Expert
    puggy666
    Level 1 Expert
    gbob59
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
