Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
LCD Tv doesnot recieve signal from apple computer
Hi, I have HDMI cable between my Mac (Ive tried both MacMini and MacBookPro). The LCD tv does not recieve a signal. When I connect the cord to a PC monitor it works fine. The cable is HDMI in the computer-end, and I have an adapter in the monitor end where it is a standard monitor connection. I conisider to get another cable for the TV that fit the LCD Tv HDMI outlet. But I guess the problem is either that the Tv has another standard than the computer or the small adapter might be broken. could there be something else wrong?
  • Anonymous Mar 13, 2014
    I Have icraig HDMI smart TV adapter is there updates or apps ??
  • 36 Answers
Try and borrow an adapter from a friend and see if it works. :)
Posted on Jan 22, 2009
I am trying to connect my LCD Hi-def television to my computer so I can watch internet on my tv. The tv is showing "invalid signal". What is this and how do I fix it? I have the dynex DVI-D to...
You can only use your TV for viewing internet from your computer by using the TV as a PC monitor. To do this you should connect your computer to your TV using a standard VGA cable - the same as you would use to connect your computer to any other external monitor. You should note that this cable doesn't carry a sound signal so you can't use the TV speakers for sound output.
However, you can connect an HDMI cable from your computer to your TV to play media files or DVDs. This cable does carry a sound signal so you will be able to use your TV speakers here. This cable cannot be used for turning your TV into a PC monitor.
And all of above shouldn't be confused with "Internet TV". This is something totally different and requires your TV to be connected directly to the internet.
Hope this helps.
Nov 07, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Dec 29, 2009 | Apple Computers & Internet
I want to watch TV through my Apple Mac computer.
you will need a DVI cable i believe. if your tv has HDMI, then you will need a DVI to HDMI cable. you may also need a converter sold by Apple to connect the tv.
Nov 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Trying to get computer to display on my tv
you mean your tv doesnt recieve signals from your computer try using a monitor and a tv first at the same time then go to the graphic video to change it from monitor to lcd tv.
Apr 29, 2009 | Computers & Internet
Trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Jan 24, 2009 | Televison & Video
Can a macbook pro work with a hannspree 28" LCD monitor?
I cant see why not, On you TV you have incomming port called HDMI, on your mac you have an outgoing port called MiniDislay for DVI.
You can use that port whit an adapter to make it to a real DVI, the you need another adapter to reform the DVI to HDMI. It can be done, its a little bit tricky, but it can be done.
here is the spec on your mac
And here are the spec for yor tv
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 14, 2008 | Hannspree 28" Widescreen Flat-Panel LCD HD...
PS3 - Sony Reciever HT-SF2300 - Aquas A83 LCD TV
Make sure you have selected the HDMI output option in the PS3 menu, otherwise you will get no picture or sound, connect you standard cable to your tv first which came with PS3 to do this first.
Nov 25, 2008 | Sony Playstation 3 (PS3) Console
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
478 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
