Back to:
Tags:
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Cancel an incoming fax in the memory (by 4 users)
posted by Hattie on Oct 08, 2006
An incoming fax was 17 pp long, and 15 of them are unnecessary. The only way I know of to prevent them from printing is to remove the paper, but obviously, that's not an adequate solution, since I also can't receive any more faxes. How can I cancel the print job in the memory?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by acullop, posted on Aug 27, 2008
An insurance company needed to send a 97 page fax of 8 1/2 x 14 copy to an office. They put in our fax number by mistake. I saw the title page come thru and did not recognize the names, companies, etc. I pulled out the paper tray, cut the power, all no good. They keep coming. We have a Sharp AR-M207. Ax sitting in corner....
Comment by Guest, posted on Jun 20, 2008
I work for a company and in my department we are only allowed to receive faxes for no more then 20 pages or so. We do everything electronically so paper isnt necessary... someone faxed me 104 pieces of paper just now and I am LIVID. how do I cancel an incomming fax?
Comment by Guest, posted on Mar 29, 2008
moving paper
Best Solution
posted on Mar 11, 2008
FixYa! (100)
kenny gomez
Rank:Wiz Wiz
Rating: 92%, 21 votes
press menu #9000*550 start
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cancel an incoming fax in the memory:
I don't want to Accept this solution
Solution #2
posted on Dec 12, 2007
Helpful (85)
checkitright
Rank:Wiz Wiz
Rating: 82%, 652 votes
Thank You!
Can you Help with these Fax Machines problems?
Fax Machines
I cannot move my address over far enough to line up the...
Fax Machines
Casio fx-260 solar calculator: (1) How to put in COMP...
Fax Machines
I have a canon c6870 copier/fax. I have loaded the...
Fax Machines
Changed the ink cartridge in my faxJET 525, but the...
Panasonic KX-FHD331 Plain Paper Thermal...
prints only 1/4 page. replaced toner,
Loading problems.
Repair Service
Find Fax Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
