F12 showing on thermostat screen wondering what it means its an honeywell 8yrs old
    Scholar:
  • 68 Answers
Many times an "F" stands as a reminder the filter needs changed, the 12 in this case could be a date, amount of days, or the F12 could be a code of some kind all together different, send me the model and all info you can get off the thermostat and we will see what it is.
Will
Posted on Nov 05, 2008
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
Honeywell DT200 thermostat is not responding to any buttons pressed. Display is showing small flame icon on left of screen and what looks like a battery in top right hand corner. Any suggestions?
The thermostat is calling for heat, and the battery icon means that the batteries are low and should be replaced. If the thermostat is wired to run on battery power alone, replacing the batteries usually corrects this problem. Hope this helps! Jim
Jan 29, 2011 | Honeywell Heating & Cooling
It is 22 degrees here in Dallas, Tx and my heater doesn't seem to want to get it any warmer than 67 degrees. My unit is only a couple years old along with my Honeywell TH6220D. Just wondering if it could...
em means emergency heat,which means you have a heat pump.check out door unit,it might be all froze up,or covered in snow,sweep snow off gently. if it's froze up its not defrosting and you need a service call.if your back up heat is not working there might be little window on furnace,look for flashing light inside.if light is steady on its working.
Jan 12, 2011 | Honeywell Programmable Thermostat Heater
I have an old (14 years) honeywell thermostat, that showed 1bat lo message on the screen. I replaced the batteries, but it still shows the same message and I cannot adjust the temp. I recall earlier...
I subjest the honeywell pro 3000 is a very good stat it comes in programable and non programable their is also a pro 8000 that is great its touch screen and has many options but the 3000 is most cost effective
Sep 14, 2010 | Honeywell Programmable Thermostat Heater
Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Sep 24, 2009 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
224 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
