Tv will not turn on. Unplugged and re-plugged a light goes on and off in back of TV. Hitachi SBX Ultravision 1999 model.
  • 1,512 Answers
Hi
It is highly likely that the set has failing electrolytic capacitors in the power supply and/or linear power stages. At this age,it is almost guaranteed. There are no serviceable parts in the set that can make for an easy fix when this sort of problem arises. For a set that age, I would recommend looking at replacements. Money spent on an old set may be a false economy as new sets of this size have some down so much in value. Happy to talk to you more about it. Sorry to be the vendor of bad news, but this is really how it is
regards
robotek
Posted on Nov 05, 2008
  • Graeme Ross
    Graeme Ross Nov 05, 2008
    The set was built 9 years ago. I am afraid all warranties will be long gone for this model. You may like to get a technician out to look at it, this will vary in costs from $40 to $100 depending on who you get to have a look. If you do get a quote for the repairs, I strongly recommend getting a Hitachi authorised agent to have a look for you. This way, you get the advantage of manufacturer backed service. I advise checking out the new digital technology to replace this older unit. You wont regret it. Good luck
    regards
    robotek
  • 19,396 Answers
=It soundl sike a possible problem with the power supply board.
The TV set must be thoroughly inspected by a technician to locate and fix the problem.
  • Ginko
    Ginko Nov 05, 2008
    The TV does not turn on and stays in standby because it is gone in protect mode, this happens when the TV main chipset detects that there is an internal problem, sugh as a wrong voltage, a capacitor that had blown, a defective integrated circuit, or any other internal fault.
    Try leaving the TVunplugged a little longer, to drain power completely, just in case the protection circuit is stuck in error mode.
    If the TV does not restart after leaving it unplugged overnight, that means that there is an internal fault, and something inside TV must be replaced or re-soldered (bad joint).
    You can call a technician using the phone number printed on the owner manual, or checking on Hitachi website, or letting us know your location.
    Calling Hitachi you can also ask the price for a warranty extension.
    A warranty extension will cover any repair for the next year in case the original warranty is expired.
    A warranty extension is oten less expensive than a single repair job.
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
I have a Hitachi SBX Ultravision 50" rear
This is a very common problem on your Hitachi model and an easy DIY fix. You can get the correct parts and instructions for this exact fix on www.TvRepairKits.com
Jan 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
TV comes on, then the blue light flashes, then stays on. The remote doesn't work when Input or menu is pushed. The remote will only turn TV on, not Off. The side buttons do not work either. I've unplugged...
Seems like a problem with the main audio/video board. Does the screen come on and stay lit? Please provide this info so that I can confirm the problem and offer you an appropriate solution.
Sai.
Oct 05, 2010 | Hitachi UltraVision 55HDS69 55 in. Plasma...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
TV Exploded
Sounds like the DLP lamp failed. You can decipher the Hitachi flashing red light. That should help to be sure.
The DLP lamp replacement is fairly straightforward and can be done with minimal tools
Sep 10, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV turns on for 2 second and then it is off
Your TV may have detected an error. Try first to have the TV unplugged overnight just to clear it out then observe it after turning it back on.
Jul 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
60.5 inch ultravision rear projection tv - circa 1999-2000
If you provide model number I can suggest correct remote control to buy.
Oct 13, 2008 | Hitachi Televison & Video
Hitachi ultravision tv
tv comes on ,i hear but can not see
Dec 27, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
626 people viewed this question
Top Televison & Video Experts
Electro Med Services...
