Question about Amana NAV3335A Top Load Washer
Amana washer "goo" on clothes?
Hi - my Amana washer (about 10 yrs old?) is depositing brownish oily "goo" on my clothes. I ran an empty cycle just with some washing soda to clear the lines, but am still getting the "goo" - there is evidence of this stuff seeping trough the holes in the base of the tub. I am suspecting a leaking seal somewhere in the motor or pump? Is it fixable? Cost effective? Any ideas wil be appreciated. Thanks in advance!
Hi there. I had a similar problem I think with my washing machine. Check the seal on the door. I found brown marks on my clothes but it wasn't from inside the machine but from when I took the clothes out and they rubbed on the rubber seal around the opening which had browny stuff on it. I just made sure to carefully remove my clothes without touching the seal until I got a new machine. Not sure if this is helpful but I hope so!
Posted on Sep 13, 2009
    Sergeant:
  • 222 Answers
You've most likely got a top transmission seal leaking. It can be fixed, but requires quite a bit of disassembly and some special tools to remove the agitator, tub, and basket. Probably at least $125 job for an independent repairman, more for a factory repairman.
There's also a possibility that a bad top transmission bearing/bushing is what caused the seal to start leaking. If that's the case, the repair becomes almost prohibitively expensive on a 10-year-old washer, but there's almost no way to tell till the repairman tears it down.
So you have a cost/benefit analysis to make. Is it worth $150 to repair a washer that's worth $75 after you fix it, but which might give you another 10 years of service. It's up to you, but you might also consider that newer machines also have better features, like water saving cycles and improved cleaning cycles.
Posted on Sep 12, 2009
    President:
  • 878 Answers
Ann, these Amana's are the mother of all washers to change out the seal and bearings. It's possible you just have a lot of gunk built up on the inside of the basket from years of washing. I would not put a cent into it. You are better off getting a new direct drive washer. Catriver...post back.
Posted on Oct 08, 2006
Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
Jan 08, 2015 | Whirlpool Washing Machines
Our tumble action front-loader washer just recently started leaving black marks in the pattern of the holes on the inside of the washer drum- We ran it twice without anything in the washer, and it still...
Thanks for stopping by:
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some de-greaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa!!
Aug 03, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Grease Spots
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 25, 2010 | GE WSXH208A Front Load Washer
Washer depositing oily stains on clothing HELP
Best way is the old fashioned way. Purchase some soda chrystals and pop them in ur drw. The same amount as you would normally use in detergent powder. Then put the washer on the hottest setting and wash the machine out. Do not put any clothes in the washer at the same time though. This will clean the washer it may take a couple of attempts to clean but doing this once a month will keep on top of it.
Hope this helps
Mar 28, 2010 | Whirlpool Washing Machines
Grease or rust ?? My front loading whirlpool duet washer is
Jan 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore he3 washer is about 10 years old and the first generation. It is leaving oily stains on the clothes, how can I fix this?
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dark spots on laundry from kenmore washer
Sep 05, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Oil spots on clothing from washer. Is the transmission leaking or perhaps another problem? Washer is about 5-6 years old
Jun 17, 2009 | Washing Machines
My washer has a really bad smell like musty if i leave the doors closed or if I leave clothes in for a couple of hours is this a probem with them
hi there,
the musty smell is from the door boot or gasket. deposit from clothes and detergent get trapped in there and have nowhere else to go. i would recommend purchasing Washerfresh tables to get rid of the deposits. they are available all over.
Dec 04, 2008 | Frigidaire ATF6000ES Front Load Washer
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
See all Amana NAV3335A Top Load Washer Questions
Amana NAV3335A Top Load Washer Logo
655 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
