Question about Hitachi 50V720 Television
Hitachi 50v720 what do i have to remove to get to the bulb.
You need to remove the front panel of the TV. If you look at the picture above, this panel is the light gray piece on the bottom of the tv. It is attached with plactic connectors. Just poo it off and then you will see a metal panel with some screws. remove the panel and then you will see the light buld casing. Pull it out and replace it with the new light bulb casing. If you did not purchase a new light bulb casing and bought just the bulb, you will need to take the casing apart and replace the bulb. Make sure to mark the wires so you will know where they should be connect to the new bulb.
Posted on Jan 13, 2009
Dark picture after changing bulb
If not bright again and not a generic bulb-possible problem with the lamp ballast that powers the lamp.
Nov 05, 2012 | Hitachi Televison & Video
Need to know how to access the box to replace the lamp 50v720
there should be a panel on the back to remove r just a screw holding it in,just dont handle the bulb with your bare hands!!! good luck
Jul 13, 2011 | Hitachi Televison & Video
Replaced the lamp on a hitachi 50V720, single lamp bulb is flashing red...how do you reset the new bulb?
Hi,no reset, Just make sure the Box (Lamp Enclosure) is pushed in firmly on both sides, left and right. Left side to hit the power connection and Right side to hit the little relay switch, Must be flush against that back side.
it happened to me and I was kicking myself in the ***, a entire weekend went by with a brand new lamp sitting in the enclosure but not completely set in correctly with a flashing red light.
Also get the outside lamp cover in just right where it touches the sensor and sits flush. That's what helped for me.
Good luck.
May 28, 2011 | Hitachi 50V720 Television
How do I change the bulb in my 50V720
Regarding your modle number, you tv part number is UX21517, so here's a video and picture guide of how to replace it.. .
http://guides.fixyourdlp.com/hitachi/UX21517.php
Jul 16, 2009 | Hitachi Televison & Video
My hitachi 50v720 bulb blew and the replacement doesn't fit
I believe the lamp you need is the UX21516. not the 21517
I have a 50VF820 and this is the lamp for it.
By the way my unit just hit the 3 years and the lamp just blew as well.
Dec 14, 2008 | Hitachi 50V720 Television
No, it is not a Sony -- it is a Hitachi 50V720
Check this link for the user manual it has the steps on how to replace the lamp hopefully that will be the needed information that you're looking for http://www.hdtvsolutions.com/pdf/50V720.pdf
Hope that helps...........
Aug 31, 2008 | Hitachi 50V720 Television
BLUE SPOT OR HAZE
We had this problem with our Hitachi and it slowly spread. Turns out it was a bad lamp/bulb and needed to be replaced. But the repair man told us the spots are usually red, so a lot of repair men might misdiagnose the problem.
Jun 27, 2008 | Hitachi 50V720 Television
Blue Haze
yeah I have the blue haze also whats up?
May 20, 2008 | Hitachi 50V720 Television
Hitachi 50v720 tv
Light engine is going bad. I had the same problem.
Oct 22, 2007 | Hitachi 50V720 Television
Hitachi 50V720 Television Logo
106 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
