Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Belkin 54g Wireless
I got one of the above to connect to laptops and ps3, the two laptops ok but ps3 do not get connected, need the setting for the ps3 please
  • Anonymous Dec 21, 2008
    I am not getting a connection; do I need to enter something in the wlan security setting?
  • 488 Answers
Please try this
tep 1:
Make sure that your wireless Internet is turned on and working properly.
Step 2:
Turn on the Playstation 3 game console.
Step 3:
Access the "Network Settings" screen under the "Settings" screen in the main menu.
Step 4:
Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
Step 5:
Select "easy" on the new screen that pops up asking what type of installation you want to use.
Step 6:
Select "wireless" when it asks you what type of Internet connection you have.
Step 7:
Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
Step 8:
Select your home Internet when the screen pops up displaying the available Internet options.
Step 9:
Save your settings on the next screen.
Step 10:
Test the connection to make sure that it works properly.
Make sure your wireless Internet connection is at full strength.
Hope it helps!
Posted on Nov 05, 2008
Bad Belkin 54g Connection Problems!
reboot your modem then reboot the router that should fix it
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
I forget my Belkin 54g wireless password and I can't get my daughter's laptop to connect to it as a result. Any suggestions
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Feb 23, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Change my settings from wep to wpa I have a belkin 54g
when you change the wireless security on the router , it is recommended tht you will change the wireless network name also ( SSID ). Because when you try to connect to the wireless network on the computer, your computer will try to connect to the same old network name with the old wireless security settings. To avoid this you can change the wireless network name. WPA is supported by windows XP SP2 and above operating system.
If the operating system on your computer WINDOWS XP SP1 and if you are trying to connect using the windows utility then you would not be able to connect to the network .
Click Here for more information about the routers and networking
Jan 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My son is trying to connect his new Laptop a Packard Bell Easynote TJ65 (windows 7) to a Belkin 54G wirelessly. It detects the router but won't connect and the troubleshooter cannot detect a problem - any...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 12, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
There is no internet working with the Belkin G wireless Router
How do you have your connection set up? Normally, your modem connects to the router, and router to computers, this is how yours is set up? Since your router is wireless-capable, just make sure that your laptop has its wireless turned on and you have the router's "Wireless" set up, name (SSID) is done, security method chosen. I like WEP-PSK[TKIP] for its simplicity, keeping in mind that all logins to your network will need this passcode as well.
Nov 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Configure the belkin54g
I had to restore my laptop to the manufature original settings. My belkin54g wireless router is showing up but it won't let me connect. When I go into network connections iw ould see Not connected firewalled. How can i fix this
Jun 30, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
220 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
