Orifices - parts
Trying to convert this 1980 unvented gas heater to LP gas. Having trouble finding the orifices for it. Can you help?
An LP gas technician can take your old orifice, fill the hole, and redrill it to the correct aperture for LP gas. Usually only a couple of bucks.
Posted on Nov 06, 2008
If I need to convert my Martin unvented fireplace from nature gas to lp cause I have propane already
You need a conversion kit. The igniter orifices are different for LP. Go to the stove store and ask for one for your model.
Dec 14, 2016 | Heating & Cooling
Convert to natural gas
To convert the heater to natural gas you will need to change the orifices in the gas unit to natural gas. I am assuming you now have it on LP gas. Hope this helps. You should have someone who knows to change the orifices over. Most appliance parts dealer carry them.
Jul 18, 2016 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Can i get parts to convert my capn cook 4 burner bbq grill to lp
The BBQ's Galore grills are the only ones that are approved to be field converted. All you need a 4 LP Gas Burner Orifices and a Hose Regulator Assembly to hook to a LP Gas grill tank. You can buy the orifices from BBQ's Galore and the Hose/Regulator Assembly from any hardware store or home improvement center that sells grills & accessories for about $30.00. Gas grill burner orifices are pretty universal, so any LP Gas ones should work.
Hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
I converted my 40'' Figidaire range to LP a few years back when I did not have access to natural gas. Now I need to convert it back. I do not still have the old parts and there seems to be no ''Natural gas...
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
Sep 25, 2009 | Frigidaire PLCF489AC Dual Fuel (Electric...
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
