Question about RCA 27V530T 27" TV
RCA 27V530T 27" TV
Hi... I recently acquired this tv for "storage" until my friend has more room. She reported that the screen would go to black and white after a while but if you turned it off and on (sometimes several times) it would go back. Well, I connected it to my satellite/dvd and it worked fine except after several hours of being idle my dvd shuts off and it causes an "unusable signal" screen to appear on the tv even after I turned the dvd back on. I could do the on/off thing several times and it would restore the picture; however, now it doesn't seem to want to reset itself (if thats what you call it)and show a picture at all. I tried running it through where the dvd doesnt have to be on but it would not read the signal at all except briefly when I first hooked it up but after that it kept saying unusable signal. It does work if I run directly from satellite box to the tv but I like to record several programs so using that route is not an option for me. I have an old Sylvania that works like a charm through the same set up but it's only 19" however, the picture is much better. I expect this RCA problem involves the tuning but I can't seem to get it to read the outputs. I have tried output 1 with absolute no success so the set up I described above is through the front/side output. Hope someone can help....it's kinda nice to watch a larger screen tv, but not if I have to constantly adjust it!!! At least I have the old tv up and running for the moment. Again, thanks for any help!
  • KAE BOO Oct 08, 2006
    Thanks for your help, I appreciate it. The chassis is ITC 008FBK. I'm somewhat handy but no tv repair experience so I'll just leave it alone!
  • Anonymous Dec 11, 2008
    I have a 32' R.C.A. T.V. and just today it has started turning off and on by itself every few seconds. Every now and a then I can see a box pop up that says Time needs to be restored. What do I do to fix this.
    President:
  • 3,130 Answers
You may have a couple of problems here.. It souds as the tuner is intermittant and a common capacitor in the power supply is bad.. Depending on the chassis, and I think its a CTC 185 I think if your handy you can get a fully repaired board for this set at http://ptscorp.com. If you have no tv reoair exoerience, you should give back the set and be done with it. Its all up to you. This set will most likly cost 200 to 225 to have a shop repair it and I think itys not worth that. Good Luck
Posted on Oct 08, 2006
RCA TV. No picture yet has sound.
I unplugged the tv and the cable box and pulled out the battery of controls for 12 hours. When I turn on again, the tv and cable box back to normal.
Jan 24, 2010 | RCA Televison & Video
My 27'' tube rca tv turns off a little after i turn it on what could be the problem
it may be recieving to much power from the grid and its tripping the circuit breaker to prevent any kind of damage
sorry not sure of how to fix this one
Oct 09, 2009 | RCA 27V530T 27" TV
Won't turn on, relays click repeatedly
Flyback is the most problem assiociated with the clicking so a replacement will solve the issue..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 21, 2009 | RCA 27V530T 27" TV
Power cord
you would need a qualified tv personal to re- insert the power chord
Jan 20, 2009 | RCA 27V530T 27" TV
Powers on and off
hello my friend,this tv uses a switched mode power supply that's the first thing i would check and the horizontal drive xtor is a common problem on this tvs
caypianan@yahoo.com
Oct 04, 2008 | RCA 27V530T 27" TV
RCA 27V530T Powers up and plays perfect for about 5 min then shuts off
look for cold solder joints on primary side of power supply
Jul 01, 2008 | RCA 27V530T 27" TV
Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Mar 27, 2008 | RCA 27V530T 27" TV
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
RCA 27V530T 27" TV Logo
196 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
