Question about Kenmore 13202 Top Load Washer
Hotpoint aquarius wf340
Hi my hotpoint aquarius wf340 wont spin out all the water can you help
  • Anonymous Mar 12, 2014
    Wont switch on
    Genius:
  • 1,036 Answers
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Posted on Nov 05, 2008
Hi we have a hotpoint aquarius extar 1300 spin wma46 that wont spin at all even with no clothes in ?
hello is it pumping out water if not check the pump for blockages it has to pump water out first then it should go into spin cycle. if does pump water out and still not spinning then there could be a problem with the module board this control the motor speeds hope it helps
regards
shaun
Mar 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Hi, My hotpoint wm 25 wont spin? Brushes are fine. Help!
Why no spin?..Is the water fully pumped out, is it out of load balance? This happens when too few items are in the drum the machine senses this and will not spin.......Hope this of some help
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Aug 08, 2009 | Hotpoint Washing Machines
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Feb 14, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius deluxe1000 WM22 Its not working........
Surely by now you've checked to see if your water inlet into the machine is good, ie turn on the taps. The machine wont start if there is no water coming in. Try the spin only function, it works??
Sep 17, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore 13202 Top Load Washer Logo
670 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
