Question about Durabrand DWT2405 24" TV
Right speaker not working
I have a Durabrand 24" and when I use an XBOX system, the right speaker will not work after I put in the A/V cables. since the tv only has two plugs and the XBOX has three. when I switch the Audio cables I can hear the othter side but still in the same speaker. I bought two of these tv's and they both have the same problem. This problem was present when I bought it from Wal Mart.
    President:
  • 3,130 Answers
If it happens on both TVs and when you switch the cables and the other side works, then it is not the TV set and something with the Xbox or the cables going to the Xbox.
Posted on Oct 08, 2006
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
Need Manual For Durabrand HT395
Durabrand HT-395 User Guide
If that link doesn't work, you can still find the manual with the following link:
www.retrevo.com
Just put HT-395 into the search box in the upper right corner and the page to download the manual should appear.
Feb 13, 2009 | Durabrand HT-3915 System
Durabrand HT-3917 System Problem W/Rt Frt Spkr
chck the wire fist if it is ok, use tester turn to X10,
Jul 25, 2008 | Durabrand HT-3915 System
Durabrand Surround Sound Right Front No Output
Nevermind....I feel like an idiot, but I had the balance all the way to the left on the media program on my computer....
Mar 02, 2008 | Durabrand 5.1 Surround Sound Computer...
Durabrand TV model DWT 2405
Unfortunetly no it is not. But if you use a cable box it will still work next year. Sorry
Feb 24, 2008 | Durabrand DWT2405 24" TV
Durabrand television model Dwt 2405
Dear friend, Try connecting a pair of Headphones to the Headphone socket in the front of the TV. Do you get sound in both headphones? If yes, then it means that the Right speaker has become faulty. No sound in Right Headphone? Then the Audio Amplifier IC has to be replaced.
Jun 19, 2007 | Durabrand DWT2405 24" TV
Durabrand DWT2405 24" TV Logo
48 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
