Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The control is not triggering the machine to work
I have a Whirlpool ultra care ii and the tub filled with water and then just stopped. I tried to reset the breaker and that is not the issue. I also tried to unplug and replug it to trigger it but nothing seems to work. I have tried to different cycles but the machine is not triggering to send a message to the controls. Is there a reset button or something I am not trying?
  • ntofflemire Nov 05, 2008
    Washing machine stops after filling with water.
  • Anonymous Nov 10, 2008
    fills with water and stops
I called a repair man. Labor was a bit pricey. $88 and it was fixed.
Posted on Nov 15, 2008
Lid switch will cause simliar problems. No spin, no agitate and will not drain water. $30.00 part and easy replacement (two screws and a plug located under lid
Posted on Nov 14, 2008
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine won't stop filling up
PRESSURE SWITCH
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Apr 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Starting a wash, tub overflows and keeps filling...
Sounds like there's a water level sensor problem. The water level sensor works by reacting to the air pressure in a tube connected to the tank. You need to open up the control panel. You may need to remove some screws, but on some machines you can "pop it" by prying it up with a putty knife. You'll find that the water sensor is the back of the knob that controls the water level. If it's a digital machine the sensor will be somewhere else but connected to a clear plastic tube. The first thing you should check is to unplug the tube from the sensor, and blow in it to make it's not just clogged with lint. If the tube flows freely, you'll need to replace to the water level sensor. This is pretty easy to do.
Dec 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Whirlpool Ultimate Care II Model #LSW9750PW3
Most likely you have broken lid switch.
Part number is 8318084
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer machine Whirlpool Ultimate Care II LSQ9549L is leaking water when I fill the tub with water. I opened cabinet and there is a small white box below the tub that is dripping water. My questions are...
is it filling filling filling and not stopping. or will it fill and stop when it is supposed to. if it's fill fill filling could be a hole in the pressure hose or a faulty pressure switch. but if itt does all the cycles and is leaking you probably have a bad pump tip the unit back a little so you can see under but do not tip all the way you will see the pump. see if it leaking if so replace tha pump.
Jan 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not fill with water
Is your drain hose lower than the top of the cabinet?? The curved part of the drain hose needs to be slightly higher than the top of the cabinet. Also, the drain hose must have an air gap around it where it goes into the house drain. It sounds to me like your washer is syphoning water out through the drain hose as it is trying to fill. Hope this helps..............
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
168 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
