Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
My remote control doesn't work straight out of the box
My remote control isn't working and is straight out of the box... i'm pretty sure i've put the battery in properly so is it just a faulty remote?
  • yuvarajvima Dec 06, 2008
    I dont know how to open the remote and put in the battery. So I am unable to test it. Rest all works great.
  • 55 Answers
Test the remote with a digital camera. Is the appliance under warranty? If not then you can try to repair the remote according to my instructions here: http://www.google.co.nz/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FRepair-your-remote-controls%2F&ei=mpVVSrr6O4_-sgP0-oDPDg&usg=AFQjCNGyomjVuVMr6mFT1L36ffi06FhCDg&sig2=kheNi9TulBWzmhGOMiIX7g
Posted on Jul 09, 2009
Agk 10133
Some times the remote you have no set-up codes to none of these devices. http://electrohelponline.blogspot.com/. Check this link, and try some other codes to your devices. Wish you sucess.
Jun 10, 2013 | Universal Remote Control Televison & Video
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
My old ps2 controller is not working. i used a new controller but it still doesn't work. the new controller was tested on another unit and it works fine. so i guess its the console itself is the...
See if your ps2 controller hub or port is damaged. If any pin is twisted try to get it straight and if you can't fix it, take the console to a service center.
Oct 13, 2011 | Sony PlayStation 2 (PS2) Console
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
Sep 24, 2011 | Panasonic DMR-E55 DVD Recorder
Romote control is not working.there is a battery in it ,red light comes up but fan is not reponding.is there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
http://www.huntershoponline.com/cc_contactus.asp
Aug 26, 2011 | Hunter (25417) Ceiling Fan
My tv control doesn't work and i put new battery's in and that didn't work either
There's a quick test you can do to test the functionality of the remote to make sure it isn't the TV's IR sensor that's broken. To perform the test all you need is the remote and a digital camera (cell phone cam works too). Take the remote and look at the IR "eye" through the camera's screen. Don't actually take a picture simply use the camera as you would a magnifying glass. While looking at the IR eye press a few buttons on the remote. If the remote is working you should see light coming out of the remote. Our eyes cant see the IR light but the camera can. If the remote doesn't light up then the remote is at fault. You can replace your remote on many websites for somewhere in the 20 - 50 dollar range.
http://www.replacementremotes.com/
Here for example, you need to input your TV model number and it will tell you what remote you need with pictures. Then, once you are sure that is the remote you want, you can order right from the same website.
Hope that helps!
Jul 19, 2011 | Televison & Video
I have a Toshiba BDX2100 Blu Ray player. I've owned it since October 2010. I've not had any problems with it until a couple of days ago. It won't turn off unless I unplug it, and it only opens...
Do you have the Blu Ray player plugged into a surge protector, sometimes surge protectors can cause odd feedback in certain electronics and cause them to be buggy. If this is the case, take it off the surge protector and plug it straight into the wall and see if that fixes the problem. If this isn't the case or doesn't solve the problem there could be a number of reasons this is happening, there could have been a surge that fried some internal components causing the player to not function correctly, or it could have just had a hardware malfunction. If this doesn't help I would recommend calling the manufacturer of the player to see if they can provide you with additional info
Jul 18, 2011 | Video Game Consoles & Games
I have a soniq 42"
Ah, the old universal remote isn't so universal anymore is it? Most "universal" remote controls were designed for the old tube type television sets. There are some seriously nice universal remotes for new flat screen TV's, but most of them are pretty pricey. The only reasonable flat screen universal remote that I've found (that actually works) is the Vizio HDTV Universal Remote. It's about $25, and believe it or not ... Wal-Mart carries it in the store.
May 16, 2011 | Televison & Video
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
390 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
