Question about Acer AL1916W 19" LCD Monitor
Horizontal lines scrolling on monitor
Acer AL1619W LCD monitor
I have a problem with dark lines, of equal width and frequency scrolling down the screen at a constant speed. The speed is at its slowest when the resolution is set at 1024x768 with the frequ set at 70 Hz. Setting the frequ to 60 or 75 Hz. Increases the speed of the scrolling, as does setting the resolution to 800x600 or 1152x 864 also increases the speed.
The scrolling lines appear to be approximately 12 to 15 mm in depth, the full width of the screen and tend to darken the background colour, eg., light grey turns to mid grey, white turns to a very pale grey thet is almost unnoticable. The darker the colour, the more noticable the line or band.
The band has a sharp edge at its top edge and fades to the back-ground over the lower 4 to 6 mm.
This problem exists at all times, even when not connected to the computer.
I assume this is a timing problem of some description but I don't know. Any suggestions will be greatly appreciated.
Thank you
  • akamine_chan Nov 14, 2008
    I have the exact same problem as rrvau described above. I updated my graphics drivers and it slowed down the speed of the scrolling lines.
    Any ideas? Bad monitor, bad video card?
  • 16 Answers
SOURCE: Acer AL1715 17 in. Flat Panel LCD
call the service center instead of wasting time
Posted on Aug 29, 2007
  • 68 Answers
SOURCE: Ripping horizontal lines on background
Your problem is not the drivers or hardware it is in your settings. Goto windows hardware settings for your monitor. Look down where it says refresh rate. Write that number down then go to the manufactures web site. Enter in your favorite search engine your monitor model and to to the manufactures site. Check to see what they recomend as your optimum and maximum refresh rates. Pay attention to the screen size also this plays a huge role in performance and out of sink refresh rates. Just out of coureosity are you overclocking your cpu or ram?
Posted on Sep 20, 2007
The Joat
  • 81 Answers
SOURCE: Preset
Without knowing any more about your system I can only give you a couple of general ideas.
First try updating to the newest video card drivers possible.
You can try going to the drivers tab in display adapters in device manager and click update drivers.
Failing this, if your system is more than a few years old you will probably have to update to a more current video card to get the resolution that you need.
The native resolution for your screen is 1280x1024.
Posted on Jan 05, 2008
  • 180 Answers
SOURCE: Annoying discolouration across monitor
Does your monitor uses external Power Supply Unit ?
May be the video board need services.
Posted on Apr 19, 2008
  • 186 Answers
SOURCE: ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Posted on Apr 30, 2008
Screen horizondally pulled right side and screen rolled to left side
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
Very horizontal faint white lines running down the screen
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 would get a Blue screen...check if the lines appear on this screen...if it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Wide, snowy horizontal bars scrolling on Viewsonic VA1912WB
Changing computers doesn't help. Followed all suggestions from Viewsonic Tech Support. Problem is in monitor circuits--had to replace it.
Dec 23, 2009 | Acer AL1916W 19" LCD Monitor
The Acer monitor's horizontal and vertical is set
use the function button on your moniter and scroll until you see the setting you want to change and increase it or decrese it from there.
Jul 16, 2009 | Acer AL1916W 19" LCD Monitor
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
White horizontal lines of static on monitor
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Apr 10, 2008 | HP Pavilion F1703 17" LCD Monitor
Horizontal lines lcd monitor
I think monitor is defective. Contact manufature
Dec 13, 2007 | Relisys RLT1720 17" LCD Monitor
Acer 5100, Lines throughout screen!!
connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Dec 11, 2007 | Acer Aspire 5100 Notebook
ViewSonic vx2025wm
Check the cable for bent pins try the monitor on another computer using THAT computers cable. Then come back
Jun 01, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
553 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
