Question about Hitachi 43F300 43" Rear Projection Television
Color problem my hitachi tv has missed up colors where the every thing seems yellow
  • nbeseikri Nov 05, 2008
    i think people should say there opinion if it is relevant otherwise it will be radicleous
    Genius:
  • 2,920 Answers
Have the tv converged to see if that wont help
Posted on Nov 05, 2008
Hitachi TV repair
Hello... Rear Projection TVs are not easy to work on. That being said, color issues can be caused by several different things. The most common involves the CRTs (there are three small picture tubes). There is a fluid in each tube that over time can dis-color, and involves a very difficult procedure to fix. Next, there are convergence circuits for each CRT, and one or more can fail. This will not usually cause the symptom you are describing, it will usually cause a double image in some or all areas of the screen and some areas the colors will look fine while other areas will not. It could also be a bad CRT drive board, or the video processing IC. It could even be the high voltage splitter! If I were you, I'd consider a new TV (please get the extended warranty). I hope this helps...
Nov 26, 2017 | Hitachi 46F500 46" Rear Projection...
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Near the top of the tv the objects are double exposed with in blue and yellow color.At the top of the tv in a light color you can see a faint color of yellow and blue that sort of swoops down like a...
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Hitachi or look for your light engine online.God bless you and your house!
Nov 25, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
Mar 23, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Hitachi TV Problems
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 23, 2007 | Hitachi 43F300 43" Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Color fade
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
