Question about SanDisk Sansa e260 MP3 Player
Charging when i go for a charge my player ,it doesn't response as charging and also it doesn't charge with electric charger. When i connect with computer it shows connecting but it lacks the display of charging sign. And i am unable to work with my player. PLEASE HELP ME.
  • 47 Answers
Sounds faulty to me, id return it for a new one if i were you. but before you do try updating it, might be a firmware problem. if your unsure how to do that. just go here and install the program.
Posted on Nov 07, 2008
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
I lost my charger to my mp3, where can I get a new one that doesn't cost much?
You can charge the MP3 player by connecting the USB cable to the MP3 player and then plug it into the USB port of your computer.
Jul 14, 2012 | Coby MP620 MP3 Player
I have a garmin nuvi 200. I'm having problems trying to charge the device. I have tried charging it in my car as well as the computer. Once I try charging it a black screen appears that says garmin as...
This is meant to happen when it's connected to your computer but not to your car charger. Sometimes it happens, when connected to a car charger, because the mini USB plug on the charger lead doesn't go in far enough into the satnav. It feels like it's fully in but it's not. If you push it in further it should solve the problem.
It takes 8 hours approx to charge a satnav connected to your computer but only 4 hours approx with the car charger or mains charger.
Apr 22, 2011 | Garmin nuvi 200W GPS Receiver
No power mp5 i use a cell phone charger in my mp5
What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Alternately you can charge it from your computer by using USB cable. It automatically charges when connected to a USB port
Dec 06, 2010 | JVC XA-MP51 (512 MB) MP3 Player ()
My fuse wont charge at all. i bought a new charger and still get no charge
Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode
Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0
Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Depending on what Sansa player you have, make sure it's up to date with the latest Firmware.
AC charger (optional)
AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available at SanDisk web site.
Dec 04, 2010 | SanDisk Sansa Fuse MP3 Player
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
When using USB hookup to computer ,does this also charge the iriver 1lp4 player.
it charges the player when connected to a computer, typically most mp3 players are charged through the usb cable when connected to the computer unless the player has built in wall charger.
Jul 03, 2009 | iRiver 1LP4WHT / 1LP4BLK / 1LP4PNK ...
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
Charging on AC
The Charging Voltage Will depend On Your Countrys Existing Supply Voltage. If Your Standard Electrical Current ( In Home ) Is 110v Then You Would Use This.
******* Please Note:- MP3 And MP4 Players, only usually charge at a low current voltage Between 5-12 Volts.
Always ensure That You Have The Correct Adapter/Charging Lead For Your Appliance****
Failure To heed This Advice, Could Lead To Shock Or Fatality.
If you are In Any Doubt, Connect The Device To a PC Or Laptop With A USB Connecting Cable. This Will also Charge The device, as well as Being Able to transfer Data.
Mike @ Compurepair.
Feb 28, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
