Question about HP Photosmart 7450 InkJet Printer
Noisy hp7450 printer
My HP7450 printer rattles at the right hand side of the carraige but prints fine
What could be the problem
  • hotfix98 Nov 24, 2008
    Solved the problem
  • 3 Answers
There's a rubber part in the printer on the right inside the printer underneath the print carriage that slides back and forth. If this has moved it will foul the print head. I moved mine back into the right place and the print head now moves freely.
Hope this helps,
Cheers,
Paul.
Posted on Nov 23, 2008
Printer has become noisy
Go to settings and then choose "Quite Mode"
Dec 24, 2015 | Samsung ML 1610 Laser Printer
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
I have HP Photosmart 7450 printer and want to install on HP pavalion a620n computer. I downloaded the driver for Windows 7 system. Still I cannot install the printer. Please HELP.
Please describe more about your problem. If you've downloaded the drivers, have you installed them? That is, have you run the setup program for installing the HP7450 on the HP Pavilion computer? When you run the setup program, part of the process will search for the HP7450. Are you connecting with the USB cable and have you check that it is securely seated in both the computer and printer? Is your printer turned on so the computer can find it during the search process?
Jun 17, 2011 | HP Photosmart 7450 InkJet Printer
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Every time I send a document to print, I get the message, "Paper Mismatch. Paper detected does not match paper size of type selected. Change paper and press OK on the hp officejet to continue...
When you print the document then select the size of the paper you want that to be print in. It will ask you when you print the document. It might be the case the default A4 size is set to other.
Try it might it can help you out.If not leave a comment will provide another solution.
Oct 11, 2010 | HP OfficeJet 7310 All-In-One InkJet...
On an HP PSC 950, I'm getting a repeated "Press Enter to Align Cartridges" message when I try to copy. Got a response from a previous expert that wasn't even applicable to this model, and no response...
hello, the reason your printer is constantly trying to align cartridges, is it did not complete the alignment, machine must complete alignment, so this message will go away, this machine requires all #15 black ink cartridge and #78 color ink cartridge, it requires the color ink to be working since it uses either yellow or magenta ink for calibration,also black ink has to working for this to work. now if the ink cartridges are known good ink or printing ink cartridges, then the problem maybe the sensor that detects the color when it prints, you may try with a soft wet or damp paper towel, when cover is open as if you are replacing the inks, unplug printer from power, move carraige to left alittle bit more, on the right hand side of carraige, you might see a black piece of plastic, behind that is the sensor, use the wet towel and wipe the bottom part of carraige and sensor, do this several times. now go ahead and close machine and power up, see if machine will pickup paper, print the calibration page. if all is working it should pass.
Oct 06, 2010 | HP PSC 950 All-In-One InkJet Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Will only print 5 discs and then quit.
there is a magnetic strip in each cartridge of ink under the label. If you open up the cover of the unit on the left hand side facing the unit, you will see a bracketwith a circuit board on it that the ink carraige slides over. Under the board there is a magnetic reader(like a credit card machine) the ink carraige slides by and it reeads the ink to make sure it's proprietary cartridges. the reader has to be very close to the cartridge or it will send the machine into error mode after 5 discs and not drop any more. You have to physically bend the metal arm down till the readers within a few mm's of the cartridge (like the width of a quarter) this will fix your problem.
Sep 29, 2006 | MicroBoards PF-2 InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
