Question about BenQ PDP-46W1 46 in. HD-Ready Plasma Television
Horizontal lines on lower portion of screen
TV worked fine in the morning about seven days ago. At night when I turned the tv on there were about seven black lines horizontally varying in width on the lower 1/3 of the screen. They have been there ever since and will not go away. The tv is hooked through the vcr, but the lines are there when the tv is hooked up to anything else as well. I have a switch box which allows the tv to be hooked to several peripheral devices. The problem is not the tv being hooked through the vcr because all those connections are correct. What could the problem be?
    President:
  • 3,130 Answers
Your problem is a bad matrix drive circuit or a drive connection cable. There are no user replaceable parts inside this set, so Im sorry to say, you are going to need to call in a trained plasma repair person. good luck!
Posted on Oct 08, 2006
  • 400 Answers
I have a "Home-fix" for you, you should watch this you tube video on how to repair a symptom such as yours even though it is a sanyo tv the fix is pretty much the same for your television and may save you oodles of money!
http://www.youtube.com/watch?v=purk_SyiT44
Good Luck!
Rich Lilja
Posted on Dec 29, 2013
Screen doesnt work, sound works fine. It worked fine last night but wouldnt turn on this morning, why?
is the screen dark?, if is it, see if the TRC filament is light, if is it afirmative, turn a little clockwise the fly back knob that say SCREEN and watch if there is a horizontal line at midle of the tv screen. if is it, your problem is in the vertical stage.
Apr 10, 2010 | Sylvania 6427GG 27" TV
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba TV -- horizontal line
sounds like you have feild colapse.take off the back and on the ciruit look for the horizontal and when you get it sue a screw driver and a mirror. put the mirror in front of the tv once you locate the horizontal plug the tv back on and look at the mirror and as soon as you turn the horizontal you will see the picture come back up to the correct size, if no good???? take it out and get a new one if you look on the side off the component you must get tthe same for safety, solder the new component in and try again
Apr 20, 2009 | Toshiba Televison & Video
Toshiba 32D46 - White Lines at Top Of Display and TV Not Turning
as i've read you statement your tv need to check parts by parts, the one you mention upside trace vertical line, that part control on vertical ckt faulty parts nearly to faded filter capacitor you can directly replace all capacitor of vertical section. the one you adjust is that the playback transformer the upper portion is focus and the lower portion is screen voltage controlling screen voltage supply to crt g2 pin. if you turn this high that resulting hazing sound come from 2nd anode cup.
Mar 29, 2009 | Toshiba 32D46 32" TV
My Gateway LCD Monitor was fine last night this morning to my surprise the screen was full of blue and white horizontal lines. I tried restarting the computer and then I couldn't even get it to turn on....
the montor wont turn on? or the pc?
the lines mean you may need to have the bulb changed. The bulb should last up to four years but sometimes you get a dud. It also depends on whether you bought the TV new or not. If that's the case, you don't know how long that TV ran each day or for how many days it was on display.
Feb 27, 2009 | Computers & Internet
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Grey screen, white lines
adjust your screen at the back of tv flyback down you see the fucos and screen adjust the sreen ok
Nov 06, 2006 | Panasonic CT-36G34 36" TV
Toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Sep 05, 2006 | Toshiba 27A30 27" TV
BenQ PDP-46W1 46 in. HD-Ready Plasma Television Logo
134 people viewed this question
Top BenQ Televison & Video Experts
Marvin
Marvin
Lawrence Oravetz
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
