Question about Teac DV-3000 DVD Player
Audio playing at a lower pitch
I am not sure if this was posted earlier today:
The audio of my DVD player is sounding a lot lower in pitch than is correct. Everyone sings and talks in a very deep voice. I have tried searching for a "KEY" facility in the "SETUP" menu which many other DVD players have, but to no avail.
HELP!!!!!!!!!!
If pushing the "Slow" button again on your remote or returning to defaults in the menu doesn't return it to correct playback, Sony has a DVP-SR200P for $38 at Walmart.
Posted on Jan 05, 2010
Turn Sound ON, now it's "Q SOUND OFF""
follow this steps and fix it. God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 09, 2013 | Televison & Video
Problem with voice sound on DVD player FX900 Sony. Can hear audio (music) fine but voices are muted.
you have probaly changed audio tracks on the dvd,just go to menu and audio,and pick another audio track,a lot of DVDs come with more than 1 audio track (im talking the actual DVD not the player
Aug 17, 2009 | Sony DVP-FX810 Portable DVD Player
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
I have a 50 incch samsung tv with samsung surrond sound/receiver/dvd player. I have no voices when we play a dvd but the music plays what is wrong
You need to have the audio from the DVD player hooked up to the same input path on the receiver.(if your running video thru the receiver) DVD audio should be hooked up to either an analog input (RCA cables) or Digital input like Digital Coaxial or Optical. Next to where you are plugging in these cables will be writing like "DVD optical" or "DVD digital". Then, make sure you switch the input of the receiver to "DVD" then it should work fine. If you still have problems post a comment and I will help some more. Hope this helps
Jun 14, 2009 | Audio Players & Recorders
No DVD sound LiteOn LH-20A1L
The audio lines from the DVD player should be hooked up to the sound card.  If the two audio wires are not connected, no audio will happen.
Sep 21, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
No sound
you have to check your cable connections,may bee you connect it in a wrong way,observe this ..
1.from your dvd the output sound should insert into input sounds of your TV.
2.check your remote control of your dvd.if it's working maybe the battery is weak already.replace with new one
Apr 01, 2008 | Cyberhome CH-DVD 300 DVD Player
No sound while playing dvd/cd
sound muting circuitery prblem or sound swiching section problem can occure this type fault.sometimes it can be cd /dvd printed board problem.give it to qulifid technician .
nuwan.
Dec 12, 2007 | JVC FS-S77S DVD Micro Component Stereo...
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Nov 19, 2007 | JVC RX-778V
Lost sound on DVD
I have a CH-DVD 300--not sure how different it is from the 200, but I have the same problem. Putting in an audio CD seems to do the trick, and is less hassle than unplugging (which also works for me).
May 20, 2007 | Cyberhome CH-DVD 300 DVD Player
I am having problems hooking it up to an HD Receiver from Direct TV
playback and record are 2 different things. playback, you connect the DVD player audio-video OUT to the audio-video IN of the TV. recording, you connect the DVD player from the audio-video IN to the audio-video OUT of the source (i.e. cable box, set-top box, etc) hope this helps!
Oct 29, 2006 | Samsung DVDR120 DVD Recorder
Teac DV-3000 DVD Player Logo
150 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
