Question about Dryers
Crusada tumble not blowing hot air i have replace the 2 rear thermostaes but still no hot air is there a third and were is it. thanks paul
  • Anonymous Apr 16, 2009
    I have the same problem. My dryer is turning, but it does not get hot. I have replaced the heating ailment, and the thermostat.
    I had someone from the a repair place come by and tell me that the blower on inside is not working and it is going to cost 250 for the part and another 150 for the service. My problem is, I don't know how to get to the inside of the blower, something about i have to totally disassemble the dryer to get to it.
    Does that sound right???? Thank You
  • 135 Answers
On the older creda models there is a third cutout which is located behind the front panel at the bottom of the filter housing.
Posted on Nov 05, 2008
Kia Sedona- center and third row heating vents blowing cold air
This model has a rear heat/cold blend door actuator. Its an electric motor that moves the duct door from hot to cold. When they wear out, they're usually stuck on the last setting
Nov 13, 2013 | Kia Cars & Trucks
There is a separate button on the lower dash labeled RR HTR for the rear heater. If you do not engage the switch it will blow cold air.
95 Chevy Surburban. Air conditioning issue, front air blows warm, rear unit blows cold. Have replaced orface 3 times, replaced compressor 3 times, replaced accumulator 2 times, flushed condensor,...
they run off of the same compressor if rear is cold and front is hot the hot and cold function in the heater box is not working possible cable problem ? or a vacum line under dash
Aug 04, 2010 | 1995 Chevrolet Suburban
2005 escalade rear a/c blowing cool air .front a/c blowing hot
More than likely, you have a blend door actuator problem. Locate the faulty actuator under the dash, usually on the firewall, and replace.
Jul 19, 2010 | 2005 Cadillac Escalade Esv
I put a new radaitor and thermosta in my 2004
Check the coolant level one more time, sounds like it could still be low.
Nov 16, 2009 | 2004 Nissan Titan
1992 Chevrolet Suburban: The front a/c works
Hi there. Your rear expansion valve is stuck. (has 2 tubes and a small tube out the top. Inside rear unit off to one side of evaporator..) Tap on it with system running. You may need to replace it.
Thanks
Paul
Jul 11, 2009 | Heating & Cooling
Kenmore air conditoner model 580.75151500 keeps blowing the built in breaker on the cord. Air conditioner is only about two years old. Happens no matter where I plug it in
Hi there. Clean the condenser. (the outside cooling coil where hot air comes out.) Use compressed air. If no air, try a vacuum.
Thanks
Paul
Jul 11, 2009 | Kenmore 75085 Air Conditioner
Hot air coming out of vent when air is on.
put some frion in and change out the antifreeze
Apr 19, 2009 | 2001 Ford F150 Styleside SuperCrew
Little heat when on third and fourth blower range.
Sound like you have a plugged heater core. But two things you need to check first
1). is there any air in the cooling system. Check this by removing the radiator cap when engine is cold and vehicle is on level ground. Is the radiator level all the way to the top? If so...
2). Check to see if your inside heater/cooling doors under the dash are working properly. If so you most likely have a partially plugged heater core.
Jan 06, 2009 | 1998 Dodge Dakota
Rear a/c blowing hot, front a/c blowing fine, cold air
that is true, however there are doors under the dash that direct the air. it is apparent that at least 1 or 2 of theses doors are stuck or none functional. they are either operated by a cable or servo motor. unfortunately if it is a malfuntion motor that will have to be replaced. if it's a cable it could be that it come off and can be put back on. if it's just a jammed door then you can do this yourself and just fix the jam. these componants are located under the dash. when taking aprt the dash becareful because the are often times plastic pins and clips that can be broken during removal of the dash panel. take your time, chance are you will save your self some money. good luck. please rate this....thanks
Aug 31, 2008 | 2004 Dodge Durango
Dryers Logo
76 people viewed this question
Top Dryers Experts
