Question about Bryston 7B SST Amplifier
Amplifier for 802N+Progressiverock
For a progressive rock listener which amplifier do you suggest to drive 802N in an order 5K US Dollars.
  • 1,512 Answers
Hi
If you love prog rock, then you are probably into guitar tone, then you just may be looking for the warmth of a tube amp. Trouble is... which one. I wish I had 5K to spend on an amp:)The B&W's are a bit on the chunky side to take with you to a HiFi store to test drive amps, so perhaps call to a store with your a few of your favourite CD's/records and test drive a few tube amps with whatever speakers they claim could keep up with the 802's (there may be none:)) to at least short list yourself a few amps that you would like to try on the 802's. then get them to bring out that short list of amps back to yours, and trail em in your lounge. Probably a good idea to ring around first and see if you can find a shop that will agree up front to do this, but is the best way to buy gear. I would do it for you! You are ready to spend $5000 when all said and done, so explain to them if they want the sale, this is how its gonna go. It is impossible to trail anything properly without it being in your listening environment. Hope this advice helps, I have been repairing amps for HiFi shops my whole life, and the good ones will work with you in this way. Cheers
regards
robotek
Posted on Nov 06, 2008
How to openline voda fone 802n
You will be needing a computer application for that.
Mar 30, 2013 | Sabrent USB-802N Wireless 802.11n USB 2.0...
I have no power to the wheels on my 92 integra--do i need to replace both axels???
I would suggest replacing the passenger side and then driving the car and listen for any popping noise while turning your vehicle to identify problems with the drivers side. Depending on the cost of the boot replacement the shaft can be just a few dollars more, I priced a boot for my pickup the other day and the cost was 43.oo and the shaft was only 52.00 complete. I suggest just replacing the part that you know is broken and then listen for any other damage. I will follow your progress. You dont want to be a parts replacer until you know for certain that the part is bad.
Nov 24, 2011 | 1992 Acura Integra Hatchback
They speakers, when they hit hard they make this odd... smacking sound.. Also on just like.. eminem songs and some rock songs that I listen to whenever the subs hit the vocals get distorted, but when I...
Well it sounds like you need a mono block amplifier for the subwoofers. Subwoofers are ment for low frequency. If you try to run regular audio through the subwoofer the sound will become distorted at a high volume. If you have a crossover on the amplifier try putting it on LP. Also do not exceed the RMX rateing on the subwoofer because if you do they will also distort. If you try adding the mono block on to it and it is still doing it you may also be running to much power to the subwoofers.
Jun 13, 2011 | Alpine SWS-1043D Car Subwoofer
Big screen RCA 52" flash green light on three times and shut off. Will not stay on , had a tech look at it he said power supply. We replace that, it continue to do the same thang. Now techician saying its...
power supply's are hardly ever replaced, they are repaired. your picture tube in most cases usually fail slowly progressively over time, there are many protection circuits involved in a TV`s circuit, they protect your unit from faults like power supply faults, picture convergence, vertical amplifiers, x ray, ext depending on your model, i suggest you search out a second opinion form another organization before spending 600 plus dollars for a new tube, i suspect your tech may be a little less than honorable...
Apr 26, 2010 | Philips Magnavox 9P6034C 60" Rear...
Oil type?
5w20. I recommend MOBIL 1 and change it every 5k miles.
Dec 19, 2009 | 2006 Honda Odyssey
I have a 1950s Montgomery Ward tube amp -- same model as Silvertone 1432. This 10-watt amp suddenly doesn't have any sound out of the mic input jack. Sounds fine in all other input jacks. Could it be a...
There is a or should be a 12AX7 preamp tube driving the microphone side of the amp. That tube could be bad, they are only about 15 to 20 dollars for a new one, don't worry about NOS stuff, waste of money if you ask me. Tung Sol makes good 12AX7s. Also check the volume control. Spray it out with some contact cleaner and rotate the control about 10 times, this will get rid of any dust or oxidation that has occured over time.
Since you don't get any sound it should be just a tube replacement.
Dec 15, 2009 | Washburn Amplifiers: 25 WATT Guitar...
Dell 4700c
take off the side panel of the computer and listen to it a little closer when its on. there are very few actual moving parts so i should be fairly easy to isolate the noise. if it's a fan anywhere in the computer it can be replaced for less than 20 dollars and shouldn't be left till it dies, replace it , it's protecting something.
If it's a cd drive making the noise , it can be replaced for 25 dollars.
If it's the hard drive, then you need to back up your important files AS SOON AS POSSIBLE, because when it crashes, you generally have a hard time retrieving stored information from it.
hard drives can be replaced for 50 to 150 dollars depending on type and how large it is.
Most times the noise from a computer comes from the fans and power supply, then the cd/dvd roms , then the hard drive : so check them in that order. post here again if you need further assistance.. Regards
Mar 31, 2009 | Dell Dimension 4700C PC Desktop
Games unreadable for xbox 360
Sorry but it sounds like you need the drive replaced. We offer the lowest prices available for this type of service. Email us with drive type for free estimate. xbox360fixer@verizon.net
Jan 27, 2009 | Microsoft Xbox 360 Console
Ipod tracks in random order
TURN OF YOUR SHUFFLE MODE BY GOING TO SETTINGS AND THEN IPOD AND SHUFFLE TURN OFF.
FOR ANYMORE INFO GO TO APPLE.COM/SUPPORT
THANK YOU APPLE GENIUS BAR
May 19, 2008 | Apple iPhone Smartphone
Bryston 7B SST Amplifier Logo
50 people viewed this question
Top Bryston Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bryston Audio Player and Recorder Expert? Answer questions, earn points and help others
