Question about Acer Aspire 3680 Laptop
Internet connection to BBC radio and others times out
In last month or so I have not been able to enjoy BBC radio 3, Classic fm, and other similar stations because the connection appears to time out in half an hour or less.
How to turn radio on dell laptop?
There isn't an FM radio built into this unit. So maybe you are trying to get internet connected radio stations to play perhaps?
You can do a search for a program called a "radio Aggregator" which allows you to receive radio stations form all over the world. or you can just go to your favourite radio station an see if the stream live music over the web.
This is a radio station in England that I listen to via the internet from time to time, but most big radio stations stream these days.
BBC Radio 1
Jun 23, 2014 | Toshiba Satellite A135-S2276 Notebook
Tip
How to Crack/Wipe DRM from Downloaded BBC iPlayer Programs
Quoted from: iPlayer ripper
BBC iPlayer - A service that lets you catch up with radio and television programs from the past week of BBC. BBC iPlayer use Microsoft's "Play for Sure" DRM system as copyright protection, thus the programs are downloaded, they will self destruct after 30 days because it is 'DRM License protected'. And once played you have up to seven days to finish watching the program. BBC Content will be automatically deleted from your computer once its expiry date has been reached. If you are outside the UK and connected to the internet you can only listen live and listen again to most of our radio programs.
BBC iPlayer Ripper - Daniusoft DRM Converter makes it easy to remove DRM protection from downloaded BBC iPlayer programs, such as DRM protected WMV video files, to make these programs DRM free and non seven or thirty days time limited so that we can save BBC contents permanently, Or you can Rip BBC iPlayer programs to any portable devices like iPad, iPod, PSP, Zen, Walkman, etc? Or even can we burn the files downloaded from iPlayer to DVD disc.
In the following passage I am going to show you how to use Daniusoft DRM Converter to remove DRM protection from BBC iPlayer programs step by step.
Step 1: Free download Daniusoft DRM Converter. Install and launch it as what you usually do with other application software.
Step 2: Click the "Add" button to import downloaded BBC iPlayer programs files, or directly drag and drop them into the main window.
Step 3: Then click the low-right "Setting" button, on the setting board there are many options to costomize the output audio & video properties. Choose an ideal output file size and quality to meet your players' requirement.
Step 4: After finishing the settings, backward to main interface, click "Start" to begin the conversion process. When conversion done, you go with DRM-free BBC iPlayer programs in various formats, or enjoy BBC iPlayer video music on any portable devices like iPad, iPhone 4, iPod touch 4, PSP, Zen, Walkman, etc?
__________________________
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes
on Oct 18, 2010 | Computers & Internet
I am using a Denon internet radio on LAN (pirelli modem), works fine, but I cannot receive BBC. BBC on the PC works fine. Could that be a router problem? Any ports or adjustments I have to consider? If so,...
I have the same problems with my Pirelli modem in Austria (A1) trying to play BBC radio stations. I connected my Denon CEOL RCD-N7 to a different network (SilverServer in Austria) and it played the BBC radio stations swimmingly (not sure what modem was used btw)... I have another internet radio at home (Reciva based) and surprisingly, that one plays the BBC stations fine using the WMA streams.
I do have a workaround now for the Denon system: I have added the following URLs (AAC streams) to "My Added Stations" on RadioDenon.com and they work like a charm:
http://www.bbc.co.uk/radio/listen/live/r1_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r2_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r3_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4x_aaclca.pls
Any suggestions as to what the issue might be with the Pirelli modem are welcome!
-- Hope this helps.
Jan 29, 2013 | Denon Audio Players & Recorders
I have an ipod classic 160gb and i go under settings/main menu and i have radio checked isnt it supposed too??
Do you mean that you don't have access to the radio because you need the optional radio piece which connects to the bottom of the device if you wish to use the radio. You can either purchase the radio device or go without radio.
Mar 01, 2011 | Apple iPod classic MP3 Player
How do I get the BBC on the Grundig S350?
You need to know the broadcast frequencies (or wavwlengths) and the times at which BBC is broadcasting towards you part of the world. With frequency in hand tune in to it at the time BBC is broadcasting towards your location. There is a book which is published annualy. The title of the book is World Radio Handbook or some such thing.
Jan 08, 2011 | Grundig S350 AM/FM/SW Radio
I WANT TO RECORD A RADIO PROGRAMME BY DOWNLOADING
Are you in the UK?
1 The easiest thing to do is to record it using a freeview box onto either a video or other recorder.
2 If that's not possible try listen again if on bbc.
3 It's difficult to record directly onto a pc without a tv capture card (and essentially doing 1 above) when you can set a timer to do it automatically.
4 if you don't have that you can connect the headphone output to the microphone input and use the Windows Sound Recorder to then recod the outpu
Nov 08, 2009 | Packard Bell Easy One Silver 2120 Notebook
Audio Recording
There are many streaming audio recorder. But I prefer Wondershare Streaming Audio Recorder,It can download streaming video offline,you can download aol radio,myspace music and so on.
http://www.download-streaming-video.com/streaming-audio-recoder/#137
You can have a try.
Mar 28, 2008 | Dell Dimension 3000 PC Desktop
DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Feb 22, 2008 | Audio Players & Recorders
Acer Aspire 3680 Laptop Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
