Question about Bosch Dishwashers
My bosch dishwasher model she6ap02uc has error code h01. What does this mean?
SOURCE: Display has error code h01
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Posted on Sep 19, 2011
  • 109 Answers
SOURCE: What is error code 2H
doesnt sound like an error code it sounds like its the delayed start feature, not sure that bosch ever used error codes
Posted on Jul 07, 2009
  • 37 Answers
SOURCE: What does the error code LE mean on my LG Dishwasher
MAin wash motor needs replacing
Affordable Appliance Repair
Lake Forest, CA 92630
Posted on Aug 22, 2009
  • 228 Answers
SOURCE: error code 01 on bosch dishwasher
error code 01 means interrupted heating phase or no heat on final rinse if machine is heating on beginning of wash this will be a blocked transfer hose or pressure chamber need to remove left hand side panel to access and base panel to access transfer hose it will be full of food deposits messing up water fill cycles these machines will only heat correctly when wash water is at correct level. the wash perfprmance will suffer till this is done.
Posted on May 27, 2010
  • 7 Answers
SOURCE: My one month old Bosch dishwasher Model SHE6AF06UC
think this means that your water pressure is not high enough for rinsing to be completed 100%. do you have low water pressure.
Posted on Jun 19, 2010
Bosch Silenceplus 44...just out of warranty... My dishwasher has an E 27 error code and will not start, anyone have any ideas?
What is the reason for the appearance of the e27 error of the Bosch dishwasher? What does it mean? In the instructions for different models of Bosch dishwashers, the e27 error is described as insufficient voltage in the electrical network. This means that if the mains voltage drops below 220V (or 110V in some countries), the dishwasher stops working, and the E27 error code appears. The most common failure occurs in the evening when the load on the network is maximum. That is why some the kitchen appliance owners use the delayed start function. Having loaded the device in the evening and having chosen the start in three hours, the dishwasher automatically turns on at night, and in the morning, you can get clean dishes.
The second way that will help to fix the E27 error of the Bosch dishwasher is to connect it to the electrical network via a voltage regulator.
Read more: https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-e27/#Xrs8gAxpRuyRckCC.99
There are videos here as well
Bosch Silenceplus 44 27 error code Google Search
Oct 15, 2018 | Bosch Dishwashers
How to start a diagnosis test on Bosch dishwasher model SHE3ARF6UC/21 will not start because of E01 code
Error code E01 means that your Bosch dishwasher is experiencing trouble with the motor.
Feb 19, 2018 | Bosch Washing Machines
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
Display has error code h01 and dishwasher won't run model is SMS63M08AU
Mar 06, 2011 | Bosch Dishwashers
My one month old Bosch dishwasher Model SHE6AF06UC has and error code E-01. It was there when I came home. Can't find anything on this.
Jun 19, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
Bosch Dishwasher Model SHU5316UC-06 -- what does error code 2H mean?
2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
Mar 28, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
1,702 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
