Question about Dryers
Zanussi jetstream 1250 coin between inner & outer drum
It sounds like a coin had got between the inner & outer drums - is there a simple way to remove it please?
  • grm0 Nov 05, 2008
    Thanks for the advice. However, I have already done that and the coin was not there. I guess it is stuck at the front of the drum or somewhere out of sight (and out of reach of a bent coar hanger).
    Thanks again
    Graham Marsh
Could be something stuck down the back of the drum. remove the hose at the rear rhs viewed from the back and you can see down the back of the drum.
tresilla
Posted on Nov 06, 2008
    President:
  • 1,462 Answers
Not that easy.
remove top. remove water hoses.remove rear half of cabinet. to do this, undo securing screws along top flange, remove two screws at bottom sides hidden behind plastic plugs and two screws at bottom back. rear half of cabinet will then pull off.
remove heater - this is held with a 10mm nut in the centre which loosen and prise heater out.
you canb then see into the gap between tub and drum ane remove coin or whatever
Posted on Nov 05, 2008
How do you remove inner drum on top loading LG Washer WT5170HV?
The whole top of machine must be removed.
unplug electronics and hoses remove upper splash ring remove cap in center of agitator remove bolt holding down remove .
remove inner tub Nut center tube should lift up and out.
next step if your changing shaft is all from bottom.
lot more down there. Take picture b4 and as you remove for ref. to resemble
Jul 03, 2016 | LG Wave WT5170HV 27" Top-Load Washer with...
How does coins and buttons make their way through those little holes in the washer
It does not go through the little holes in the drum, but there is a space between inner drum and outer solid drum. usually in spin cycle things like coins and sometime socks and underwear's will go through and end up in pump. If it does not drain properly, you need to openup hose from drum to pump and remove these items. That is not too difficult on most machines. It is at the bottom of the machine.
Sep 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have azanussi zwf1437w washing machine. The drum has become stuck and won't turn and can't be turned by hand. There are no socks etc stuck between the inner and outer drum that I can see.
Well, I hate to tell you, but the drum will have to be looked at and that means opening the machine up. It probably dislodged from its mounts from excess vibration caused by unbalanced loads in the drum.
Jan 15, 2013 | Zanussi Washing Machines
Why has my front loading washing machine started to rattle, knock and squeak during the spin cycle
If the drum is loose and you can feel loose play when you lift the lip of the inner drum, you probably have bearing problems and/or a broken arm on the rear of the inner drum. However a coin caught between the inner and outer drums isn't good news either. Find a tech to diagnose and explain...Good luck.....Nomess
Apr 20, 2010 | Whirlpool Washing Machines
Cause of noisy spinning
your drum bearings have gotten water into them from a defective inner drum lip seal,now you need to tear down the machine and replace the lip seal and also replace both inner and outer drum bearings
Apr 18, 2010 | Zanussi ZWF1430W Front Load Washer
My zanussi f1045w is grinding when spinning what could the problem be
Hi there.....the problem could be ...(a) something traped between the inner and outer drum....usually a bra wire....(b) Debri in the drain pump can result in grinding noise...(c) CRACKED inner drum spider unit..and or failed main bearings..test for this by opening the door with appliance switched off place your hand at outter edge of inner drum and test for lift in drum..there should'nt be any lift at all
regards Sir Galahad
Aug 12, 2009 | Zanussi F1045W Front Load Washer
CLUNKING NOISE - SOMETHING TRAPPED BETWEEN INNER & OUTER DRUMS?
Yes, there is something trapped between the inner and outer drum, you could try removing the sump hose from the bottom of the drum, this will give you more room to fish about than possibly removing the heater. If you do remove the heater, you may not get it back in, then you will have to fit a new one.
The sump hose is the large hose fastened to the bottom of the outer tub.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Makes a noise like there are rocks or coins when it spins
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Drum is not easy to turn
clothes caught between inner and outer drum .get them out !!!clothes hanger could be used to fish them out Good Luck Eire
Nov 18, 2007 | Zanussi FLE1416W Front Load Washer
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Dryers Logo
314 people viewed this question
Top Dryers Experts
