Question about RCA RS2650 Shelf System
CD tray won't open and motor running
The CD tray would never open, but I only wanted to use the radio. Whenever the power cord is plugged in, I hear a motor running. The radio works fine, but how do I stop the motor? The unit is out of waranty now. I couldn't find the manual on Sam's or any place else.
  • Anonymous Dec 23, 2007
    how do you open the cd door , motor is running and door won't open
I know this is an old post but I saw it through google, because I had the same problem. I ended up tearing the CD door off and was able to look in and see that one of the cds was stuck. The player was trying to play disc 1 but had pulled disc 2 in under neith and it was stuck, causing the issue. As soon as I pulled disc 2 out the system works great.
Posted on May 02, 2007
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
DVD trays out - Panasonic SA-PM39D
there are very tricky mechanical devices that detect when the trays are closed and in what position they are in
A gear or mechanical piece is not in correct order or not functioning properly and will need intense studying to determine which position they all should be in at door closed , laser mech. position , standby position
can you upload a photo of the inside of the cd mechanism?
Oct 18, 2008 | Panasonic SC-DK10 System
Kracher power washer won't turn on
Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
Aug 26, 2017 | Washing Machines
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
Sharp CD-BA2100, when I turn it on it starts making a clicking sound and if set to tape one or tape two, it shows "error". When set to "cd" it comes up with error 0306 and the cd tray...
the rubber rope which conect the motor to a small gears to open the cd was cut due to long using ... this sound of clicking coz the small motor is running and its not attached to anything ... its a small rounded rubber rope ..the bad news is you have to break some plastic stuff to reach the motor in the repair depot they change the whole upper part so it costs alot ... but if you can reach it it will work perfect as its new.
Sep 08, 2011 | Sharp CD-BA200 CD Shelf System
I have a rca rs 2663 stereo, The cd tray will not open or play cd's anymore. Could you please help
It two things can cause this:-
The motor is damaged ( you can listed closely to hear if the door motor runs when you try to open the tray.
Or The belt that takes power from motor to open mechanism is damaged.
Aug 19, 2011 | RCA RS2663 Shelf System
CD tray does not operate
More than likely a belt which runs from the load/unload motor to the CD tray. Replace this and everything should work. I've done dozens of them. Unless you are pretty handy with electrical components I'd recommennd a repair shop. A straight forward repair If it's the problem I described, about 40 minutes work if that.
Just make sure there isn't a disk caught up at the rear of the tray. If you are missing a CD that's possibly where it is. That could be stopping the tray from opening.
Apr 07, 2010 | Sharp MD-R3 3-Disc CD Player
RCA RS2650 Shelf System Logo
340 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
