Question about JVC AV-27530 27" TV
JVC 35 PLASMA
HI EXPERTS THIS IS ONE FOR UR MIND I HAVE A 35" PLASMA MADE BY JVC WITH A MEDIA BOX IT DOES TURN ON AND GO INTO MENU, YOU TUNE IT IN AND THEN ONCE OUT OF MENU IT TURNS OFF! AND EITHER FLASHES SLOWLY RED OR FAST GREEN WHAT CAN THIS BE? MANY THANKS MARK ENGLAND WEB.DESIGNERA@bTCONNECT.COM
Make sure that while in the menu, the sleep timer is not being activated.
Posted on Jan 13, 2008
Can jvc vm-42wx84 be used as a monitor without tuner
This is a screen with a media box. The box has two connections to the display panel. The first looks like a DVI connector. The second is the proprietory control port connection. This is how the set receives commands about brightness, contrast etc, scaling, aspect ratio. It might even control such basics as power on/off.
You could try the panel just with a DVI connection, but you will have to make sure that all sources are scaled to the panel's native resolution (1024x768) before they reach the screen. This is part of what the media box does. You might be okay if you're driving the panel direct from a PC graphics card. But if you want to run it with a variety of different sources then you really need to use the JVC media box.
I can't say if the Hitachi media box would work.
Sep 10, 2014 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Black rectangular box on screen from doing menu
Take ur tv remote go to menu check the captioning functions turn all CC1,2,3 off and all txt off too.Yes,text functions is on,that why u getting a big black block flashing on ur screen.
Mar 28, 2010 | JVC AV-32D305 32" TV
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My JVC Plasma 42" screen TV is only 13 mths old but it does not turn on anymore. The blue button (power) comes on steady at first but then, after about 3 seconds, starts to blink and it won't go off -even...
CHECK UR POWERSETTING AND SLEEP TIMER SETTING......AND RE ADJUST IT
IF YOU STILL HAVE PROBLEMS GO IN TOUCH WITH JVC SERVICE AND ASK THEM FOR ADVISE....OR THE STORE U BOUGHT THE SET FROM
Nov 19, 2009 | JVC GM-V42UG 42 in. Plasma EDTV
My samsung plasma has lost its signel. the areial works with other tvs and the plasma works in game mode any ideas
Go back to analogue, press menu, find "Plug and Play" and follow the on screen instructions, it will redo everything back to when you first got it out of its box, its will tune analogue first, just let it search, next it will do the DTV, wait for it to finish and your done.
Thanks
Oct 02, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
Hitachi Plasma 42PD6600- THERE IS NO SOUND !!PLEASE HELP!!
Hi.
This will sort your problem.
HITACHI
42PD6600 NO SOUND
Sound value’s have been lost in memory,
to reinstate
please do the following.
ENTER SERVICE MODE. MENU- 4-7-2-5.
Go to Audio menu.
Select Sound 2.
Re-instate the following
FM PRESCALE 15
NICAM PRESCALE AVL ON 35
SCART PRESCALE AVL ON 14
SCART VOLUME AVL ON 122
THESE WILL HAVE ALL DEFAULTED TO ZERO
GO TO STANDBY TO MEMORIZE
This corruption of the NVM values are likely to have
been caused by the peripheral device connected to
AV1.
Connect that device to AV2 or if AV2 is occupied by
another device, swap AV1 and 2 over.
http://dysonmanuals.llc.nu/
Mar 30, 2008 | Televison & Video
POWER WON'T TURN ON . YES, POWER SUPPLY OUTLET IS GOOD
Replace capacitor C926 near center of circuit board chassis (label is on the bottom) by a 1000uF 50V. Mind the polarity!
R,
A
Feb 05, 2008 | JVC AV-35750 35" TV
WON'T TURN ON. POWER SUPPLY GOOD
Replace capacitor C926 near center of circuit board chassis (label is on bottom) by a 1000uF 50V one. Mind the polarity!
R,
A
Need a display tuner jvc pd-42wv74
guess what? I have the EXACT same tuner that u're looking for... my place was broken into and they TOOK the tv monitor... but left behind the tuner . smart thief. if u're interested in buying this tuner to make ur tv complete again. (its in MINT condition) email me at FAIR1968LANE@aol.com and put in JVC PD 42wv74 plasma tv in subject so i d know who it was. thanks.
Feb 01, 2008 | JVC PD-42WV74 42 in. Plasma EDTV
JVC AV-27530 27" TV Logo
54 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
