Question about Onkyo Audio Players & Recorders
Broken Female audio plug
Somehow the the base speaker got bumped and the female audio plug tip broke off in the jack. I can't get the tip out. Any suggestions? I have only had this system for 35 days.
Take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
Posted on Feb 07, 2009
  • 59 Answers
Open the speaker, and check the circuit board from where the female jack is running. jump the fmale jack and just connect some wires to the point from where the female jack is running. i ve done this many times, it works for sure
Posted on Nov 05, 2008
Trying to convert dvi to hdmi for my ps4. I can play the game and the picture is fune, but i have ni sound. What do i need to do?
You will need an HDMI to DVI adapter with audio. The DVI end of the cable should have both the DVI connection as well as a 3.5mm audio jack. You would then plug your speakers directly into the jack. If the jack is a male connector, you will need a female-to-female coupler.
Apr 09, 2016 | Norcent Technologies PM-4201 42 in....
How do i connect the following speakers to a tv?
Look for a headphone jack plugin on the TV, and if you have one then plug the speakers into that. Otherwise if you only have RCA audio jacks on the TV (red/white plug-ins), you'll need an RCA male/stereo female adapter. I did a quick search and found this one on Amazon for $1.49:
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
You could probably find one at Radioshack or a local electronics store otherwise.
Also, in case you need it, here's a link to the owner manual:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/Creature%20OM%20Rev%20A.pdf
Sep 06, 2011 | JBL CREATURE II Computer Speakers
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Missing plug in cord. The A.C. cord got lost during a move. My speakers are silver in color with a larger round speaker in the center and a smaller one above and below the larger one. The power cord...
this is called a converter jack adapter
http://cgi.ebay.com.au/2-5mm-Female-3-5mm-Male-Audio-Converter-Jack-Adapter-/170592131101?pt=AU_Electronics_Portable_Audio_Accessories&hash=item27b815581d
http://cgi.ebay.com.au/3-5mm-Female-2-5mm-Male-Audio-Converter-Jack-Adapter-/130474893240?pt=AU_Electronics_Portable_Audio_Accessories&hash=item1e60e8dfb8
both are $1 with free postage worldwide
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Apr 16, 2011 | Audio Players & Recorders
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Apr 19, 2010 | Creative Labs I-Trigue L3800 Computer...
How do i hook up speakers to my lcd?
go to Radio Shack or whoever is closest for audio cables, ask for a mini-stereo jack to RCA male jack, it should look like a Y with the stereo mini female jack on one end and two (one red one black or white) old style speaker jacks. These should take care of the audio situation. It might be better to consider adding a tuner or media center to help direct the sound.
Jun 22, 2009 | Bose Companion 2 Computer Speakers
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
Headphone problem
GO INTO CONTROL PANAL GO TO SOUND OPEN FOLDER GO TO SOUND TAB AND FIND WHAT ITEM YOU ARE HAVINGISSUES WITH HIGHLIGHT IT AND TEST IT TO.
DEVICE MANAGER IN CONTROL PANAL, CHECK THE DEVICE AND IT DRIVER AND ANY NEW UPDATES
Feb 12, 2009 | Toshiba Satellite Pro L300 Notebook
Need Audio Cable Extension
You would be looking for a Lead that has a 3.5 Ml Male Connector Jack to plug in to PC, and a 3.5 Ml Female Connection on the end in which you will plug your PC Speakers in, that will also have a 3.5 Ml Jack on the end.
Dec 09, 2008 | HP JBL Platinum Computer Speakers
Connections
What the two do is give the audio, you need a 'Y' phono (2 female to male connector adapter) and a female- female adapter to suit your speaker connector and the male end on the adapter so that you can plug in your two cables and the plug in the outlet your pc speakers plug, it will cost about £5 or $10 wherever you are. I have done it and its worth it for the picture quality. see below http://www.maplin.co.uk/Search.aspx?criteria=phono%20adaptors&source=15&SD=Y
Oct 05, 2007 | Microsoft Xbox 360 Console
202 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
