Question about Sharp Microwave Ovens
I have a Sharp Combination oven microwave. The turntable does not rotate. the unit is out of guarantee. I need to locate a repair in south Dublin.
  • 99 Answers
Sounds like drive shaft on top of motor,It comes as a spare part.
Posted on Nov 05, 2008
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
My sharp R-352DC Microwave won't heat, and turntable doesn't rotate. Please tell me the problem?
Maybe a bad fuse. If the transformer is bad that would blow the fuse. The magnetron unit may be causing it too.
Nov 17, 2016 | Sharp Microwave Ovens
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Turntable
The turntable motor will need to be replaced, a common issue.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My above the range Maytag Microwave oven plate does not rotate. Bought a new rotator wheel as the old one was broken, and the central spindle will rotate, but not with the plate on it. What can I do?
The spindle (called a turntable shaft) sits atop a small motor shaft from the turntable motor. You either have a weak turntable motor, stripped shaft (which allows the motor shaft to free spin when it has any weight on it), or both.
The turntable motor is located under the bottom panel of the microwave oven. You do not have to uninstall the oven for this repair.
First, unplug the unit, remove the glass carousel tray, and pull straight up on the turntable shaft to remove it. Next, locate and remove the series of screws along the bottom panel underneath the oven. The bottom panel will open exposing the drive motor. The motor comes out by disconnecting the connector plug and a couple of mounting screws.
If the model number you have this listed under is correct, you can view these parts at searspartsdirect.com. Locate items 11 (turntable motor) and 14 (shaft) under the "Cavity" heading. Other sites you may try are pcappliancerepair.com, appliancepartspros.com or repairclinic.com to see if you can find these parts any cheaper.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 05, 2009 | Maytag MMV4205 Microwave Oven
Sharp Microwave Lights Up, But Won't Rotate or Cook
Hi. I would suggest checking out the door switches. There are usually 3. If one of those has failed then the microwave won't operate because of safety reasons. Best to replace all three. If the display on the unit is still fully operational I'd say go for the repair.
Mar 18, 2009 | Sharp Microwave Ovens
Turntable does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
The best place to order Sharp parts is Tritronics. Or you can call them toll-free at 866-779-5835.
Dec 23, 2008 | Sharp R-530ES Microwave Oven
Plate does not rotate freely and make noice
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2008 | Sharp R-1480 Microwave Oven
How to get the plate to rotate
I'm assuming you are talking about the turntable tray. If it's not rotating, make sure your microwave does not have a feature that allows you to disable the turntable rotation (refer to your owner's manual). If it's not a simple operator function, you more than likely have a defective turntable motor. The motor is located under the bottom of the microwave oven. It is a simple repair that requires minimal tools. If you wish to attempt a repair yourself, please post your complete model number (located aorund the door opening) and I can locate a part number for you. I hope this helps you.
May 27, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
