Question about Indesit Washing Machines
Indesit WIE 167 says "test". If I get it through a cycle it goes straight on to a boil wash... help before I shrink EVERYTHING!
    Genius:
  • 1,036 Answers
There is a fault on the program board. It more than likely needs a replacement.
Posted on Nov 05, 2008
Indesit wie 147
I think you have to fill it with water first. My machine won't work unless the previous cycle has a chance to complete. i.e., it has to fill with water before the wash cycle starts, or it has to have water before it rinses/spins dry.
Mar 14, 2014 | Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Oct 07, 2009 | Washing Machines
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Bearings on a indest wie 167 washing machine
You can download a user manual for your m/c, but not a repair manual, Go to>
www.indesit .co.uk
Follow the links. To remove the spider, remove the rear panel, remove drum belt, undo drum pulley, you may have to heat the screw holding the pulley,undo all screws that you can see holding the spider to drum rear.
Withdraw spider, you may have to use some force to pull it off.
Fit new bearings or spider, and reassemble..
plz rate this solution.
Dec 15, 2008 | Indesit WA 115 Front Load Washer
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Jul 17, 2007 | Indesit W 123 Front Load Washer
INDESIT 167 Stuk on DENO
take the lid off the machine.remove or disconnect the wires off the main board giving them a small spray with a water dispersent or silicone based soloution.by the way turn the power off at the mains before carrying out this procedure.
Jun 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
205 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
