Question about Bosch Washing Machines
Scum (greasy dots) left on clothes - Bosch Washing Machines
    Genius:
  • 1,036 Answers
Try washing just an old dish towel on the hottest program, with 1 cup of soda crystals only.
Before starting this though, remove the detergent drawer, and clean it in hot soapy water. Spray a general surface cleaner into the drawer appature, and clean out as much as you can reach with a small cloth. Put drawer back and, put 2 tblespoons of soda crystals in the detergent section of the drawer too. Wash on hot.
These are mostly caused by a build up in the dispenser drawer.
Posted on Nov 05, 2008
Black greasy marks on clothes
could be build up of chemicals in pipework try a proprietry brand of washing machine cleaner worked for us !!
Jul 01, 2012 | Washing Machines
Tip
Greasy marks on cloths; All washing machines
90% of greasy marks on cloths is due to scum build in the outer bowl of your machine...top loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
on Jan 03, 2008 | Bosch WFMC 3200 Front Load Washer
My viking dishwasher is not getting the dishes clean in certain areas of the dishwasher - they come out with food still on and/or greasy residue still left on. There is a white residue on alot of the...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 01, 2011 | Viking VDB450 Dishwasher
The water supply arm for middle sprayer is not held in place by clip that is attached to bottom of dish rack. Does not meet up with water outlet on back of washer and also impedes movement of sprayer arm....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | KitchenAid KUDS40CVSS Builtin Dishwasher
Clothes getting greasy marks
There is nothing that has grease on it that can leak into the dryer I would do a good inspection in the drum and clean it.
Dec 13, 2009 | GE Dryers
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
How do I clean the machine?
Sounds like soap scum build-up. Try running it through a cycle with a cupful of vinegar added. Old-wives method, but I have hard-water, and it works often.
Sep 20, 2009 | Fisher Paykel EcoSmart GWL15
Machine leaves greasy looking streaks on clothes
tub bearing water seal gone ,needs new bearings and seals.
Jun 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
Build up of scum on inside of agitator
You should be able to remove the agitator,also try adding or spraying limeaway or clr on it during the rinse cycle
Apr 27, 2008 | Maytag Dependable Care LAT9416
Washing Machines Logo
106 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
