Question about Bosch KGU40124 Bottom Freezer Refrigerator
Bosch KGU40124 water leaking from freezer
I have a bosch KGU40124 Fridge Freezer that has recently been forming ice in the bottom of the freezer and now where else, when the bottom of the freezer is full of ice, (there is a moulded tray under the bottom drawer), water starts to leak out onto the floor.
I went away for a week recently and left the fridge off and defrosted with the doors open for the whole week, the problem returned almost straight away after it was turned back on.
Reading comments on here i assume the drain is blocked somehow... problem is... where is the drain??? I have no idea where to look for it. Does the drain run from the fridge to the freezer or just from the freezer to the evaporation tray under the fridge?
Any pointers would be appreciated.
    President:
  • 1,462 Answers
Remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Posted on Nov 05, 2008
My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
Apr 23, 2012 | Refrigerators
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Jul 26, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
We have a free standing bosch fridge/freezer, the freezer is at the bottom. Ice is forming in the bottom of the freezer, underneath the last drawer.
sounds like the drain hole in the back of the freezer has blocked and when the defrost kicks in the water is not running out of the drain hole but into the bottom of the freezer. best do a full defrost and if it occurs again the drain hole will need to be cleared out.
Mar 19, 2009 | Bosch Refrigerators
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Bosch KGU44120 frost free fridge freezer (6 years old) generates ice on floor of freezer compartment within a couple of hours. Maintains -20C temperature no problem.
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Jul 04, 2008 | Bosch Refrigerators
Bosch KGU40124 Bottom Freezer Refrigerator Logo
593 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Ken Thomas
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
