LG WD-14750SD noise coming from water pump near pump filter spay nozzle keeps on getting blocked with fine material having to pick out material with scriber and tweezers every 2 days
It sounds as if you have a screw loose !
No, really - I believe there is a screw, nail or other large object in the drum or near the filter that needs to be found and removed.
The small particles you describe are probably pieces of plastic from the drum or pump body that have been chipped off. If left untreated, can lead to a big hole and expensive replacement.
Please empty and strip the pump pipework to check for nails etc, and check in base of drum.
I have been out to several with a hole clean through the drum caused by nails.
Are there any new washing machines made that still have direct drive. That means that the agitator...
(More)
Are there any new washing machines made that still have direct drive. That means that the agitator has two pieces and is not just one part. I told my repair man that my dad had been in the appliance sales and repair for over 50 years before he passed away and he said that normally he doesn't tell people about the new washers as they would be too depressed to learn that they are all garbage. I forgot to ask if him if anyone still makes them with direct drive.
Maytag Epic MFW9800TQ0 Getting Error Code FH. I've had a repair man out to look at it, he tried...
(More)
Maytag Epic MFW9800TQ0 Getting Error Code FH. I've had a repair man out to look at it, he tried replacing the Flowmeter and the presure switch. After doing so he re-ran the diagnostics and still got FH right during C1. He said we needed to replace the control board. $255 later, new control board in place and the darn thing is still giving the FH error a minute or two into the diagnostics C1. not sure what else to do? Help, please... frustrated 9 month pregnant mother who needs to do laundry :) Thank you.
I have a Neptune TL FAV6800AW Washer that makes a tremendous grinding sound during the wash cycle....
(More)
I have a Neptune TL FAV6800AW Washer that makes a tremendous grinding sound during the wash cycle. Not nearly as loud during the rinse cycle. Also, during the last 13 minutes, the off balance code (DC) comes on and machine stops. I suspect the clutch is pretty much gone. Any suggestions of the problem and who would be recommended vendor for a replacement part. Thank you.
