Question about Samsung SF-5100 Plain Paper Laser Fax
NOT RECIEVING FAXES
OUR FAX MACHINE IS NOT WORKING I CHANGED TEH TONER ON MONDAY AND NOW IT DOESN'T WORK SAYS MEMMORY RECIEVED ON DISPLAY CAN YOU HELP
  • 161 Answers
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Posted on Nov 07, 2008
Unreadable recieved faxes
No, not worth it. A very slow, old, fax machine
Apr 19, 2010 | Brother IntelliFAX 2800 Laser Fax
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
Fax machine has toner error on screen.
sounds like you are using generic toner or rewfills, best to use oem toner
Jan 15, 2009 | Brother MFC-8460N All-In-One Printer
2800 will not recieve faxes
Some models will actually stop working whenever a drum message is displayed.
Remember, you do not need a drum to fax out (only to print confirmations) so i would go ahead and change the drum.
Ons ome models you can adjust to how low you want to set it or remove it all together.
It will store it in memory for a while (providing you do not turn off the machine, and print as soon as you replace the toner)
Jul 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
