Question about Sony 0217 Playstation 2 - Horizontal 3-D Surround Sound System Computer Speakers
Sony S Master FMStereo/FM-AM Receiver STR-KS600PM
HI, I inherited this surround sound system from a relative, but no manual. I am trying to add music from my computer through an audio cable, but Im not sure exactly where I should be plugging them into, and what settings I should be using on the system. Can anyone help?
bbtoast
  • 319 Answers
SOURCE: No sound from digital out on PS3 using optical cable
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Posted on Jan 06, 2008
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
welcomejee
  • 10594 Answers
SOURCE: LOOKING FOR A MANUAL AND A REMOTE FOR MY STR-DB 780
Please download user manual of STR-DB870 from Sony Support.
Posted on Nov 20, 2008
SOURCE: No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Posted on Feb 10, 2009
mlapres
  • 757 Answers
SOURCE: Sony PCM 48 Issue
As long as you continue to have both HDMI and optical outputs connected at same time from the cable box, it will probably always choose the default as HDMI. If you do not want to change any connections then the best thing to do in this case is to always leave the cable box turned on. Otherwise, disconnect the HDMI and connect it to the TV by component video.
Posted on Jun 18, 2009
Sony STR-DE575 5.1 Channels Receiver I have power to everything but I am getting ZERO sound. Is this something that is fixable or do I just need to replace my receiver?
Have you looked in the manual? Basic speaker setup with test tones will certify the basic hardware. Then onboard FM. Then add the compexity of external and digital sources.
Aug 26, 2011 | Sony STR-DE575 Receiver
Sony receiver made pop noise and all sound systems went mute.what are my options? STR-DE425 sony receiver with surround sound, dvd player,cd player and tv all connected thru receiver...
It sounds like the output ic's may have failed, because of the complexity of system I would have a professional come and look at the unit for an evaluation, chances are he will need to take it back to the shop for service.
Dec 30, 2010 | Sony STR-DE425 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Need instruction on how to set up to surround sound.
Go to www.sonystyle.com click on "support" Type in your model # and you will get more information the you could ever need on that receiver! Including the manual. Hope this helps!
May 22, 2009 | Sony STR-DE697 Receiver
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
No sound from back speakers
Remember the rear speakers are called surround... Did you select surround on the unit? if it says stereo then you will only get fronts, select surround to get the rest.
Jul 13, 2008 | Sony STR-DG510 Receiver
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Sep 14, 2007 | Sony STR-D865
643 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
