Question about Samsung Blackjack SGH-I607 Smartphone
Issue w/ blackjack I607 & ActiveSync
I purchased a used AT&T SGH-I607 from a friend recently, I have T-Mobile & so I had it unlocked for use. I can't get my pc & BJ to talk to each other thru ActiveSync 4.5, BJ has Windows Mobile 5. What settings do I need to change in either/both phone & pc in order to get this stuff to work?
    Brigadier General:
  • 6,966 Answers
Initially, pls try again:
  • with no other USB devices installed, reboot;
  • uninstall and then re-install ActiveSync. Before the re-install, temporarily disable all network network configuration tools (LAN, bluetooth, WiFi).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Brigadier General:
  • 3,614 Answers
Make sure that you already installed the device software for the phone on your pc to be able to do the pairing.
and make sure both blutooth was active and paired.
Keeps us more updated. Let me know.
Regards
    Sergeant:
  • 306 Answers
There never been a problem getting the BlackJack to connect to ActiveSync via USB.  Bluetooth is a little tricky but USB works great.  I suggest opening ActiveSync on the BlackJack (w/ USB Disconnected) and checking the settings.
  • On the device Home Screen press Start, scroll to and select ActiveSync.
  • On the ActiveSync page select Menu then Connections and make sure you have a check mark in the Sync all PCs using this connection, then select USB and press Done.
  • Now on the PC open ActiveSync.  Select File, Connection Settings.
  • Make sure you have a check mark in the Allow USB connections, Uncheck the "Allow Connections to One of the following" and in "This Computer is connected to" select automatic, and finally make sure you have a check in the Open ActiveSync when my device connects.
  • Press OK on the Connection Settings dialog box and connect the device with the USB cable.
That's pretty much all to get  connect to ActiveSync. .  Good Luck!
  • AbdulRahiman S Nov 05, 2008
    In any case the Windows Mobile Device Center is easy to use and seems easier to use than Activesync.
    if u download "Windows Mobile Device Center" directly from Microsoft
     then Try uninstall/reinstall WMDC and see what happens. Also, you may want to manually remove the driver for your phone and let the system re-install them. Finally, firewalls can prevent WMDC from working, even Microsoft's own OneCare. You will need manually apply some workarounds.
  • 535 Answers
Http://www.unlockit.tk/
here is the link see it
  • sandip panchal
    sandip panchal Nov 05, 2008
Free unlock code
Hi is your phone locked to network provider then free code are not available for this mobile model so better go for paid code ..You can purchase unlock code for your samsung SGH-I607 mobile from the providers like Unlock-Zone.com here they render unlock code for all mobile models at reliable cost ..You first check that whether they are rendering code for your country and network provider ..If yes then pay for it and unlock your phone ...
Aug 30, 2013 | Samsung Blackjack SGH-I607 Smartphone
I need remote code to unlock Samsung Blackjack SGH-I607
Did you enter e2p reset code first?
- *2767*3855# let it reboot
then enter...
- *7465625*638*00000000*00000000# (to change NCK code to 00000000)
then enter...
- #7465625*638*00000000# (to permanently unlock the phone)
check the lock status...
- *#7465625#
Mar 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Code to unlock samsung sgh-i607
Good place to get the unlock code for your samsung sgh-i607 model mobile ,
Just visit here Mobile-unlocker.com , it gives the easy methods to get the mobile unlocked............
Apr 18, 2012 | Samsung Blackjack SGH-I607 Smartphone
Bought samsung sgh-i607 from chennai, what is the unlock code for the imei 352794014153763
Get the unlock code for your samsung SGH-i607 model mobile from this site Superunlockcodes.com , here it gives the easy methods to get the mobile unlocked.........
Mar 15, 2012 | Samsung Blackjack SGH-I607 Smartphone
I wanted to get my phone unlock
You can unlock your mobile from network lock using code..You can get the unlock code for samsung SGH i607 from here www.mobile-unlocker.com and unlock it successfully...
Oct 07, 2011 | Samsung SGH I607 Blackjack Battery Li Ion...
Can i put the sim card from my boost mobile phone
You can use this sim card only if the blackjuack was issued by Boost Mobile also or if The blackjack is an "unlocke" phone.
May 12, 2009 | Samsung Blackjack SGH-I607 Smartphone
Unlocking my Blackjack SGH-I607
i need the unlock instructions i purchased with world wide unlock program..
Mar 26, 2008 | Samsung Blackjack SGH-I607 Smartphone
I have the same issue, Can anyone help??? I need a remote code to unlock the mobile phone1.gif (cingular) i have the IMEI.
It's for a blackjack II (i617) and desperately want to unlock it. (my phone w/t-mobile srv. is broken) IMEI 357246014347536 Please help. rakelz1qt@hotmail.com
Feb 10, 2008 | Samsung Blackjack SGH-I607 Smartphone
Need unlock code
I need to unlock my Samsung Balckjack SGH-i607
I need to unlock my device password Samsung Balckjack SGH-i607
Nov 21, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung Blackjack SGH-I607 Smartphone Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
