Question about HP Computers & Internet
Laptop HP Pavillion dv1000 will not turn on at all. Screen flickered recently (moving screen to diffenent positions overcame this temporarily) popping off to standby mode quite often, and tempremental on-off button for quite a while, now will not turn on at all. AC power fine, light comes on laptop when connected, then goes off after about a minute after on-button fails to work. I've removed and reseated the RAM (two boards) and still nothing.
Have you tried connecting an external monitor to your laptop? just a thought... once you have connected leads turn laptop and monitor on and on start up you must press an f key. On my laptop this is F5 or F6 you can usually see a picture of 2 screens on the F button. holding this down will open the laptop on the other screen.
sorry just a thought
Posted on Nov 05, 2008
  • louswiles Nov 05, 2008
    just read your post again so the last answer probably didnt seem like much help but my old acer laptop stoped turning on, my screen was smashed and it did suddenly start working again plugged into an external monitor, check the actual connectors on the battery charger connections too they can sometimes bend .,
    hey i am a complete novice so you have probably already tried all of my suggestions.
    as well as holding down the appropriate f key you need to hold down the Fn key too
  • 461 Answers
Change you RAM with known good RAM, (Make sure you insert them firmly and properly.
Once y ou PC turn on you may need to check your system registery.. you can read more details on how to do it at below link
good luck
Need step by step instruction for screen replacement of hp pavillion laptop
It would be hard if I type it here. It's better that you can see it.
There are a lot of tutorials in Youtube. I'm pretty sure that you can find one from there.
Mar 18, 2013 | HP Pavilion dv1000 Notebook
Laptop screen flickers
Probably the flex cable on your laptop is damage.
try to contact your nearest service center shop to check on it.
Dec 03, 2011 | HP Compaq Presario V5000Z Notebook
The screen is black on start up. No image at all.
The dv1000's were a limited edition notebook withmany issues. the motherboard going on them was one of them. connect the motebook to a desktop monitor if you have one and simultaneously press Fn + F4 to use the monitor as a screen. If nothing happens begin crying. Time to buy a new laptop. You information is safe but you need an IDE/SATA PCI adapter to view the files on another computer. If you were using XP, i hope you didn't password protect it making it private. That will be problem number 2.
Mar 31, 2010 | HP Pavilion dv1000 Notebook
Hp pavillion dv9000 lcd screen changes colour when moved
The inverter is to change the volts from the laptop to the Backlight. This wont have anything to do with it.
Im more than certian it will be the LCD cable. Proberly loose or torn at where the lid closes.
Hope this helps.
Feb 23, 2010 | HP Computers & Internet
Letters keep typing even without keyboard
I'd try wiping and reinstalling the operating system or booting from a linux live-cd first to see if it's a windows issue or hardware issue. In the end though, yes I believe the motherboard is probably faulty.
Jan 22, 2010 | HP Pavilion dv1000 Notebook
Power supply Problem
Might be the issue with display panel cable as well so please first try to refix it.
May 29, 2009 | HP Pavilion dv1000 Notebook
HP DV1000/screen turns on then turns off.
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out for parts, repair service and DIY info.
May 16, 2009 | HP Pavilion dv1000 Notebook
HP Pavillion dv6000 screen will not come on all the lcd hookups are fine just a blank screen any tips on what to do?
put the laptop on a lcd monitor.If work , your laptop lcd is dead ;if don't work your video proc is done.
But first of all change the memory module .
Jan 09, 2009 | HP Pavilion dv1000 Notebook
Help :( i can't start up my laptop it wont let me :(
what i can help this...
you select safe mode and remove video driver and reboot your laptop...if it inside the windows normally,try to remove some unused toolbar in add and remove programs..and check also for virus scan..and reboot computer..
Dec 16, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Computers & Internet Logo
93 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
