Question about OKI C5400 Laser Printer
Reset Counters How do I reset the counters on the OKI C5400 to get more life out of the image drums?
    President:
  • 1,653 Answers
There is no known way to do this!
Posted on Sep 11, 2009
Reset konica drum counter
has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
How to reset drum counter on bizhub 200
Utility counter, details stop00 stop01. Counters. Has the drum been replaced? if not you reset the counter the machine will assume that a new drum is install and select the proper voltages for a new drum since the drum is not new? it might code and get poor image quality issues. Replace the developer with the drum. Machine uses the counters to determine setting in the machine, developer also has a counter. Does the front panel say replace PC drum? If so replace developer and drum and cleaning blade at the same time. You clear counters before pulling out the image unit. and you don't exit all the way out of service mode after clearing the counters you hit exit once the turn off main power, Rear left side. Once new drum and developer installed. RUN F8. Do not allow copies Prints or fax until F8 is run. Or start all over again.
Jan 03, 2014 | Minolta bizhub 200 All-In-One Printer
Minolta Dialta Copier Di152, code reads 32-COF
Replace the developer and developer unit. And Replace the drum normally done together make sure to reset the drum developer counters because the machine use the counters to set voltages to the drum and developer and it is the only way the copier knows it has a new drum and developer reset the counters without replacing the drum and developer causes code sand image problems
Sep 16, 2012 | Minolta Office Equipment & Supplies
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Sep 29, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I reset the counters for drum life?
You must order a fuse from a toner supply company.
Ask for instructions but it is not a easy task. I pay someone to do mine.
Feb 17, 2010 | OKI C5500n Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
How can I reset my Drum Life Counter on my Printer?
http://my.okidata.com/PP-B4250.nsf?opendatabase
Guide Users: B4250 download user manual
American English
May 06, 2009 | OKI B4250n Laser Printer
OKI C5400 - REPLACE DRUM
To replace the drum - leave the toner in place and pull it upwards. This will remove the drum and toner together. Now release the toner from the drum. Fit the new drum - don't forget to remove the orange packing bar and replace the toner. Easy when you know how.
Apr 16, 2008 | OKI C5400 Laser Printer
Oki c5400
Drum life for C5400 is roughly 15000 pages
Feb 09, 2008 | OKI C7350hdn Led Printer
OKI C5400 Laser Printer Logo
839 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
