Question about Gateway Media Center 610XL PC Desktop
Gateway 610XL Disassembly
Does anyone have any information on how to disassemble the gateway 610XL media center? I can not seem to get past the outer monitor shell as I am trying to get to the motherboard.
  • bill_alexand Nov 06, 2008
    i need a service manual or schematic for the system 610xl
  • jbenjamin19 Nov 09, 2008
    I would love this as well. I build computers fairly regularly but this one is waaaayy too messy for me. I really need a schematic before I dig in!
Take cover off top of base.- pry off
remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
two screws on back of base and then take off back cover.remove sheild cover.
disconnect all cables. 4 screws hold power supply in.
rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
pull all cables out towards you.
remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
remove base from screen.
take out screws on back of screen. carefully pry all around case to seperate.
remove back, and then sheild. there are a few screws that hold it on.
If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Posted on Nov 09, 2008
It doesnt boot up at all , good power,but nothing past the power cord.
Most likely the power supply inside the unit is bad. Try replacing the internal powersupply.If possibe.
Jun 09, 2010 | Gateway Media Center 610XL (610XLMDIA) PC...
I need to know what graphics card to use to update
The Gateway 610 uses an AGP graphics slot so any video card with AGP hookup should work fine. The link below is to a parts site for this computer.
Gateway 610 Parts
Feb 21, 2010 | Gateway Media Center 610XL (610XLMDIA) PC...
Gateway 610 Media Center
I would then suspect the monitor.
Sounds like the video card is working.
Try another monitor to see for sure.
Sep 09, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
I have a gateway media center 610xl that has no power.
if you know on how to replace the power supply then do it, if not proceed to bring the computer. or if you have friends can do this, then much better.
Mar 15, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Screen goes on and off
This is a well known issue with gateway media centre and there is no easy solution for this problem. If you are an expert in tearing apart the system and putting it back, then this LInk has some options which have worked to many people.
Feb 01, 2009 | Gateway Media Center 610XL PC Desktop
Disassembly of Gateway 610
Found this - should help you
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
Dec 31, 2008 | Gateway Media Center 610XL PC Desktop
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Disassembly of gateway 610XL
take cover off top of base.- pry off
Nov 04, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
Looking for a manual
unless gateway will support you in this they are the only ones that can get that kind of information for you...... either that or ya could call the geek squad at best buy and have them come to your house and fix it .
Jul 19, 2008 | Gateway Media Center 610XL PC Desktop
Gateway Media Center 610XL PC Desktop Logo
1,305 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
