SOURCE: Locating Oil Filter
i think its on the front of the motor. directly above the drain plug. maybe behind a finned cover?
or go here for a free pdf service manual
http://www.carlsalter.com/motorcycle-manuals.asp
SOURCE: 02 yamaha vstar 1100, ran fine. started it the
Sounds like it may be drawing air around the intake somewhere. Let it idle and spray around carefully with wd-40 until it speeds up. This will reveal the leak.
SOURCE: Where does the oil come out of a 2004 Yamaha 1100 VStar Classic
Oil drain plug is located near the bottom of the engine, left side toward the front. The oil filter element is located on the right side of the engine under the cover toward the front. Changing the oil filter usually requires removal of the front exhaust pipe. There is an aftermarket filter relocation kit that replaces the filter element with a spin on filter that mounts on the front of the bike.
